Drag Racing Tech
KUP Water Vapor System
Old Mar 14, 2011 | 10:55 AM
Frozen WS6's Avatar
Default KUP Water Vapor System
Here are some pics of my Water Vapor System install. I ordered the whole kit to try to keep my blackbird cooler. I have my stock temp sensor in the stock location in the driver's side head, that will read 195 degrees consistantly. I also have an autometer gauge reading off the passenger side head which puts it over #8. Which will read 210-220, or more depending on traffic or if I hotlap it at the track. Which is not a good thing to have with (in my setup) larger shots of spray. We'll see how well this helps this summer when all my snow melts.
Out with the old.
To make it easier to install the driver's rear block. I removed the valve cover. It also helped that my cowling was cut away and I don't have a passenger wiper.
In with the new.
Finished install.
Now all I have to do is start it and bleed the cooling system and put my cowling plastic back on.
Old Mar 14, 2011 | 02:57 PM
Steve Burger's Avatar
LS1TECH Sponsor
Nice kit, I have one on my car and we are a dealer.
Old Mar 14, 2011 | 04:50 PM
Broke EF's Avatar
What did you put on the AN threads, and why?
Sean
Old Mar 14, 2011 | 04:54 PM
battousai's Avatar
what does this do exactly? lower temps? if so, how?
Old Mar 14, 2011 | 05:05 PM
a98ws6's Avatar
Whats the kit cost?
Old Mar 14, 2011 | 05:36 PM
whitesscamaro's Avatar
Originally Posted by a98ws6
Whats the kit cost?
$199.95 per their website. I just got mine in today.
Old Mar 14, 2011 | 05:47 PM
98hc4mula's Avatar
Would you sell your old set up? Send me a pm pls
Old Mar 14, 2011 | 05:50 PM
Frozen WS6's Avatar
Sean
I put pst sealant on them. Since I can't see the back ones I want to make damn sure they don't leak. So I just did them all. I know the AN side didn't need it, that was just preventitive.
Since they don't come with any directions and I haven't found writeups on it I did it the sameway I do any bolt that goes into a coolant passage.
Old Mar 14, 2011 | 06:15 PM
Frozen WS6's Avatar
I bought direct. I didn't know they had dealers setup.
Old Mar 14, 2011 | 06:39 PM
ATVracr's Avatar
Very nice set up and it does help !!
Old Mar 14, 2011 | 06:49 PM
Frozen WS6's Avatar
That's good to hear. ATV.
Old Mar 15, 2011 | 09:33 AM
ATwelveSec02Z28's Avatar
Yep venting all 4 corners is a GOOD THING.
I made my own with hardline, took lots of tubing and even more patience. - KUP's setup is very simple
Old Mar 15, 2011 | 08:37 PM
tomz28's Avatar
Kurt makes alot of nice parts. you should see hes shop.
i was going to get this as well but i couldnt find a way to install it as clean as i wanted too. so i made this up.
how are you going to keep the block from beating the hell out of your clean looking FAST intake
https://ls1tech.com/forums/generatio...ines-pics.html
Old Mar 15, 2011 | 09:40 PM
Frozen WS6's Avatar
Hardlines would leave alot of room and you can run them exactly where you want them for an invisible install. Nice.
I'd like to go check out his shop some day.
That's a clean setup too. I was debating with making my own lines in black like that. But these go with the rest of the black/silver theme pretty well. I just wish my fuel rails were silver also.
Surprisingly it doesn't really move. So I think it should be fine, otherwise I'll just get out the touchup paint
Old Mar 15, 2011 | 11:07 PM
camaroz28lt1at's Avatar
I cant tell how you ran it back to the radiator, just a rubber hose?
Old Mar 16, 2011 | 10:06 AM
Frozen WS6's Avatar
I hid it well. Lol. Yeah just a rubber hose like the factory did.
Old Mar 16, 2011 | 12:56 PM
Fireball's Avatar
I went totally cheap...used my OEM 4-port crossover (98-2000 style). cut off the hose nipple and welded on a -4AN Bung.
Old Mar 16, 2011 | 06:15 PM
studderin's Avatar
Looks like a really nice bolt on setup, I like stuff like that.
You can also tap the heads and put a NPT/AN fitting right in the head. and run this setup Lower profile, less fitting, less leaks, simple to work on....
Old Mar 16, 2011 | 07:22 PM
Zmg00camaross's Avatar
Can someone explain whats wrong with the factory setup. Would this be good for a street car, feel like a newb again lol. All I know is steam/vapor is air and probly could get trap in the head. Am I close here?
Old Mar 16, 2011 | 10:29 PM
slowblackbird's Avatar
i know the ls6 style may cause a steam pocket in the back of the head, but i would like to know what the advantage is over the ls1 style steam port system
