removing valley cover?using 1 without knock sensors?
little confused on this i currently have a ls6 valley cover system on my car, want to keep things simple and clean seen a couple vendors sell a valley cover without knock sensors etc.
now my question is what do you do for crankcase evap? can i just run my valve covers with -8 bungs on each cover to a catch can then 1 line to my turbo for a vacuum source?
sorry if its a dumb question still dont get this crankcase ****....
Yes -8 or -10 on each cover is fine just use a vented catch can no need for vacuum. We offer a flat valley cover for the LS1-6 that one is LSX different bolt pattern. Also have vented catch cans. Give me a call I will help you get it straightened out.
Actually Nate, ours fits ls1/ls6. LSX is a general term where "X" is replaced by any of the LS series numbers.
However it doesnt work if you want to keep the oil pressure sender integrated into the cover like some model years
Blake
Blake
