Couple battery relocation questions
1. If I'm planning on doing a killswitch later should I run 2 positive cables? The other being for the alternator later on?
2. Will 2gauge be sufficient? It's what I got in my battery relocation kit(Taylor 48101)
3. If I ground the negative terminal in the rear what should I do with the negative up front? Any pics of how you grounded that terminal?
4. Is there any enclosed battery boxes that fit like a glove in the spare tire area? I saw tue bmr option, but it's not enclosed. Looked slick though. If not I guess I can hack the Taylor box up a bit to make it fit.
Sorry, Electrical isn't my strong suit.
The battery I used was a Braille 3121 that weighs 21lbs. Cost me $178 through summit with a 2 year warranty. I did not want to run a large Red top as the whole purpose of a battery relocate is to take weight off the front and move to the rear. However I feel if you are doing something try every way possible to lighten it up as much as possible. The extra wiring ect is heavy so I tried to offset that with a race battery.
With the battery in the back with a Burkhart kit I ran my 2 guage wire from the positive terminal to the off side of the switch (I mounted my switch in the center of license plate) Then 2 guage wire from the on side of switch thru right side of car interior thru a grommet on right side of lower dash by PCM harness, behind the PCM and down to the starter. I ran a 2 guage jumper wire from the starter to the fuse block running along were the elec fan wires run all in loom nice and clean. I then ran a 4 guage wire from the altenator following the main power wire back to the positive side of the battery, NOT the switch. In the back as close to the battery I ran a 4 guage 150 amp in line fuse. I grounded the battery to the rear seat belt stud. I removed all factory wiring for the battery and removed the factory ground wire from shock tower to the engine and ran a new ground with leftover 2 gauge wire. The only issue I have yet to make sure works is the charging due to not being able to start the car obviously. Again this is the way I have done it. I see too many hacked up pics of battery relocates on this site I am suprised cars are not burning to the ground. This job took me all of a sunday pulling things apart ect and 4 evenings about 2-3 hrs each and a few hrs the following sat to finish it up. I will try to posts pics of my install. Hope this helps.
I just finished my battery relocation in my car. 2 gauge should work. I used double ot for a short ground in the back. The front ground needs to be bolted tightly to clean metal on the body somewhere. Weld on a stainless stud or drill a hole for a bolt.
Hey 03Busa where did you find the 150 amp fuse?
Could be wrong, i didn't memorize the rule book, maybe someone else can chime in.
With the dry battery you can do a rear firewall then you dont have to have the battery in the box, but if you ever put a cell in the t top hole, then you will need a battery box to seperate the battery from the cell again.
Being a dry battery saves you from having to have a vent.
Thanks, Chris
Rear firewall of 0.024 steel or 0.032 aluminum required if battery relocated to trunk. IF firewall not used, same thickness box or poly (approved NHRA box) must be used. Box must be vented to outside [[[ doesn't differentiate between Optima style or regular lead-acid batteries]]] 3/8" minimum bolts must hold down the battery with a metal hold-down strap (no fabric or plastic straps allowed)
As far as the cutout switch - - - General Regulation 8:4
If the battery is relocated, a cutout switch is mandatory. Cutout must be connected to the positive side of the electrical system... if it's a push/pull type, push MUST be the position to kill the electrical. plastic or keyed switches are prohibited. (doesn't say permanent rotary isn't allowed) just that the OFF position must be labeled clearly.
There's more, but thats the general gist of it.
GL!
