Drag Racing Tech
All options for bumper support?
Old Mar 31, 2011 | 03:34 PM
02Sweet's Avatar
Originally Posted by senicalj4579
ok so lemme get this straight. Your car is on a major diet, this is a drag race forum, but the rear wouldnt be worth it? LOL I thought it was like 20lbs just like the the front no?
Yeah yeah im cheap...lol
From what I remember it only saves 5 lbs. I could be wrong though. I still need to get a kmember before I get the bumper support. (that burkhart will be making
Old Mar 31, 2011 | 04:14 PM
senicalj4579's Avatar
Correct me if im wrong but theres no way your cheap if your buying the nice piece like that! lol.
Im being cheap having 2nd thoughts on all this weight savings stuff its insane. Its not cheap to get lightweight stuff. Im mean, where the hell does it end?! Think ill just buy a cam...lol...for now
Old Mar 31, 2011 | 05:23 PM
sweetbmxrider's Avatar
Sometimes its good to leave weight in the rear of the car. I mean if you into your weight bias and all.
Old Mar 31, 2011 | 06:54 PM
NHRAFORMULA00's Avatar
No support is really needed in the rear. As for the front ,i simply bought a heavy guage aluminum angle,(1 1/2 x 1 1/2 x 3/16 thick) and tied it across the front frame horns with 1 inch standoffs.Then bolt the bottom of the bumper cover up to the angle. I think it weighs maybe 2 lbs including all the hardware. Id post pics but im not that puter savy.Been down the race track 150-200 times in the 10s and no problems. Hows that for weight savings??
Old Mar 31, 2011 | 08:35 PM
Thats pretty good I like it. But do you think I better put something stronger in there seeing how its mostly a streecar? I wonder at what speed bumper supports become usless in crashes.
Old Mar 31, 2011 | 08:56 PM
deangoodin's Avatar
here a thought......do all you upgrades and get it so fast you cant get it stoped ,then buy parachute mount that included in the rear support......yea.....
Old Apr 1, 2011 | 08:02 AM
02Sweet's Avatar
I would run without a support if my car didn't see the street. As my car sees VERY little street time I wanted to have the safety aspect of it.
Yes the light weight stuff does get pricey. But I have slowly upgraded my car every year adding more and more. You need to think about where you want your car to be in x years or the life of ownership. Then look at how much money you want to put into it.
Old Apr 1, 2011 | 12:44 PM
HioSSilver's Avatar
here's another option you can do yourself and get back to real hotroding instead of buying parts.
 Michael S. Palmer
Old Apr 1, 2011 | 01:18 PM
Think I saw your other post somewhere. You lost 7lbs?
Old Apr 1, 2011 | 01:30 PM
TA1364's Avatar
Do you really think a couple pieces of tubing(Burkhardt support) is going to prevent anything damaga wise in a street car?
Old Apr 1, 2011 | 01:35 PM
02Sweet's Avatar
At a low speed accident I think it will make a difference vs not running anything.
Old Apr 1, 2011 | 02:05 PM
  #32
I have to agree with this. Think I read somewhere that the factory supports are only tested for 35mph and under. Im not sure if its true.
If I did any weight reduction it would be as a whole and not just one thing.
My list if I did this...
Rear seats
carpet
front and rear bumper supports
only at the track...
sway bar
skinnies up front
lighter sticky tires
Things that are gone now...
spare and jack
disk changer
air pump
and smaller things
If I could do all these things and put the car on the track what would I gain maybe .15 ? Im trying to figure if its worth it or not. Time, money, safety...IDK. I can tell you if I did do these things it would end about right there unless I turn the car into a full track car.
Old Apr 1, 2011 | 02:45 PM
  #33
1lejohn's Avatar
In the rear you can remove the plastic honeycomb and keep the fiber glass cross member. Its light compared to the plastic. Then bolt the rear body work back to it.or use the stock push pins. You can even cut holes in the rear cross member. How much protection does it offer ??? The egg crate piece is there to absorb energy in a crash. With out attaching the rear body work to some thing it will deform at speeds. It already acts like a parachute. I'm thinking of sealing mine up with expand a foam.
In the front remove the foam piece and cut holes in the metal cross member. It probally provides some protection. Doing this opens up alot of space. It saves some weight. I mounted an oil cooler and tranny cooler on the front cross member. The oil cooler has a fan the tranny sits in front of the grill opening. They recieve good air flow and gets them off of the rad. which helps the engine run cooler.
The advantage to the Burkhart pieces are the weight savings and the strength You also can lose alot of the little brackets etc. With a stock hood be careful many of the brackets need to stay so the hood will close and latch.
Old Apr 1, 2011 | 05:13 PM
  #34
HioSSilver's Avatar
Yeah something like that. That was just the bumper, who knows about all the other parts. I left alot of meat in it so I'm sure more could be cut out of it, but everything is still very sturdy. I got 9-10# out of the rear bumper and supporting rubber peice. Best of all you can do it yourself for the price of a decent hole saw kit. My car is under 3100# and still complete using this technique.
Old Apr 1, 2011 | 06:19 PM
  #35
kkslds's Avatar
The rear is about 6 pounds and is 171.00 bare and 191.00 PC. They are on the Tax sale until 4/15. Look for the rear support in an upcomming GM HighTech article.
Is the front support included in this tax sale? How much is a powder coated front support for a LS1 Trans Am?
Old Apr 1, 2011 | 07:11 PM
  #36
02Sweet's Avatar
Rear seats
carpet
sway bar
skinnies up front
spare and jack
disk changer
air pump
and smaller things
I have done a lot of different things. I have no hvac system in the car.
I have the stock stereo removed
I have all the wire associated with the radio and hvac removed from the car.
I have no washer tank, rad over flow tank is gone and a small universal one in its place.
Rear seat and belts are removed.
Im sure there are many more things I have forgot too.
Old May 14, 2011 | 07:15 AM
  #37
Bersaglieri's Avatar
QFTW
-Dustin-
Old May 14, 2011 | 07:24 AM
  #38
HioSSilver's Avatar
Originally Posted by Bersaglieri
QFTW
-Dustin-
What does that mean?
Old May 14, 2011 | 11:32 AM
  #39
Quote for the win. Meaning I wish folks would build cars instead of buying them. Everyone wants everything done for them anymore, cookie cutter everything, meh, just not for me.
-Dustin-
Old May 14, 2011 | 12:10 PM
  #40
HioSSilver's Avatar
Thanks!! I gota brush up on my lingo
