Can I run no alternator in my LS1 drag car?
im putting my supercharged 383 LS1 in a fully tubbed and 10 piont caged 68 camaro ss and ive ordered a motor plate to mount the motor ( the motor has been pushed back 6 inches and lowered 3 inches for a better launch ) so mock up the motor plate to the motor and notice on the drivers side im goin to be cuttin way too much of the motor plate for my liking because of the supercharger mounting braket and the alternator and bracket soo i wanna know if if can run without an alternator and just charge the batery every run? im going to be running an electric water pump aswell and an electric fuel pump an electric fan and the sump fir my intercooler .all guages are manual guages (oil and water) im also running a th400 manual brakes and no pwer steering an NO EMISSIONS BS can somebody help me out ?
With all the electric components you're running i suggest you find a way to include an alt. It sure beats having to run a charger between runs and the spare batteries...maybe a dual batt setup?
It's tough if you plan on running a stock PCM. There are tables that change engine parameters based off ignition voltage and when the voltage starts dropping during a run it will affect the tune. Injector offset vs ignition voltage is the only one off the top of my head but I'm pretty sure there's one dealing with the fuel pump as well.
Even with two batteries you'll probably have issues with the amount of stuff you are trying to run. Dual 16 volts would likely do the job but I have seen folks fry the stock PCM trying to switch to a 16 volt system. Aftermarket engine management would allow the 16 volts.
I don't mind charging in between runs or running a dual battery would that work ? I can get towed from the end of the track to my trailer at the end of every run and towed to the line up before but I'm wondering if it will power everything and for how long? I'm just racing for fun not for money
ill just fab the alterntor bracket i have into a manual tension one like on the old style blocks making the tensioner outta hiem joints like on a march pulley kit that should work
