Rear drag sway bar setup
Thanks guys its been a long road getting this car together and on the road and still need fine tuning.
I'm not sure where they are hitting the shocks... shouldn't be hitting at all, unless you have the spohn swaybar that was designed wrong and won't clear aftermarket shocks, which there's several threads on here about, from years past, people having the same problem....
The brackets also should be somewhat level as well.
Hope that helps.
How much angle should the links have to them?
PS I met you at Lebanon Valley when I was racing my stock SS I think you were running 9.6- 9.8 with the plate kit at the time, probably 2 summers ago.
Check that measurment that firehawk mentioned as well... as that is a potential cause as well. It's not consistant from one rear to another either, which is the bad part.
It's amazing that they are able to get away with what they get away with..... not sure who the dummy is on these types of things, the company's for nto caring if the stuff that goes out the door is right, or the customers for tolerating it.
