Drag Racing Tech
bumper cover loose with support out?
Old 04-13-2011 | 05:48 PM
meatyz's Avatar
Default bumper cover loose with support out?
im thinking bout removing the bumper support on my 2002 camaro will it make the front real loose without the support in place?
Old 04-13-2011 | 05:51 PM
Duffster's Avatar
Yes and at low speeds it will buckle. There are bumper supports available from sponsors that prevent/reduce the buckling and sagging.
Old 04-13-2011 | 06:52 PM
second_2_none's Avatar
I removed mine and havent had any problems since. But mine hasnt been out to long and it is temp till I get a bumper support from MWC. I also dont drive my car on the street for the most part, only to the track and work once a month.
Old 04-13-2011 | 08:00 PM
outtacontrolz28's Avatar
I've had mine out for about 2 years and have never had a issue
Old 04-13-2011 | 09:43 PM
Do you have an aftermarket one or nothing at all?
Old 04-14-2011 | 07:18 AM
I don't have anything at all. I just started to strip my car down for my new build, I plan on making my own little brackets for it eventually. You will be fine without it
Old 04-14-2011 | 09:11 AM
Steve Burger's Avatar
LS1TECH Sponsor
Check our site for information on supports.
Old 04-14-2011 | 09:15 AM
senicalj4579's Avatar
I would at lest have some kind of support in there. Iv searched alot on this and your nose will sag over time without some kind of support.
Old 04-14-2011 | 11:39 AM
sweetbmxrider's Avatar
Hole saw.
Old 04-14-2011 | 01:10 PM
ShiznityZ28's Avatar
YEs it will be a little loose. dont hit anything or lean on it and it will be fine drove mine for years like that. eventually ade a small support out of pencil crome moley.
Old 04-14-2011 | 01:23 PM
studderin's Avatar
I ran nothing with all the lower plastics hanging off it, and the full airdamn across. It worked for 2-3 years. I just cut that lower flap off the nose that just flaps there, took all the plastics off, drimmed the airdamn to just the middle bolls wide. So removed like 7-10#s of crap plastics hangging off the bumper so it dosnt sag anymore, was starting to pull on the tabs under the headlights. I put 4 little 1/8 x1 alum bars to the lower bumper holes and its firm now.
Old 04-14-2011 | 11:24 PM
jsteele90's Avatar
pics^^^^?
Old 04-15-2011 | 03:58 PM
studderin's Avatar
https://ls1tech.com/forums/drag-raci...h-diet-16.html
that page and the next page
Old 04-15-2011 | 08:04 PM
joelster's Avatar
I think some of you guys would be surprised what the nose of your car looks like at 100mph without any sort of support in there. I'm sure it's fine just cruising around, but if you can push on it with your foot and it moves/buckles, then it is doing that when you are going down the track.
Old 04-15-2011 | 10:22 PM
223HAWK's Avatar
Originally Posted by sweetbmxrider
Hole saw.
This!!
Old 04-15-2011 | 10:27 PM
weaklt1's Avatar
my husband made aluminum brackets for a couple of our cars and they are fine
Old 04-24-2011 | 06:49 PM
223HAWK's Avatar
This was pretty simple..I just used some alm strips from the local hardware store. I also made a bracket for my fog lights..lol its not too pretty but works!
Old 04-24-2011 | 07:19 PM
HioSSilver's Avatar
x3 on the holesaw...if you do a good job laying it out it looks cool and nobody is non the wiser...here's mine
Old 04-24-2011 | 09:46 PM
223HAWK's Avatar
Damn how did you do them so clean?? I have a hole saw kit..but damn!!
Old 04-24-2011 | 09:53 PM
HioSSilver's Avatar
I worked on professional RR cars for 17 years....ya learn some tricks along the way. It's nothing you can't do with a hole saw kit, a diegrinder and a tape measure to lay it all out. Take your time and yours could look like that too. Here's a pic of the hood hinges. You would be suprised at how much weight you can shed from all over the car.
Quick Reply: bumper cover loose with support out?
