Not stock seat belts = Airbag light problem?
I have racing seats with 5 point harnesses. My stock seat belts are gone obviously. When I stomp on the gas from a stop or even hi-way speeds, my air bag light on the dash will come on and stay on until I turn the car off. It has thrown 5 different codes at me now. See attachment.
I'm thinking it's because the factory seat belt isn't there. On the driver side their is 2 wires that go to a plug that connects to the latch part of the belt. It is disconnected and the seat belt guy on the dash doesn't come on, which is fine by me. I would guess I just need to wire the 2 together so it completes the circuit.
Can you monitor circuit resistances with that scanner? If so, what does the driver airbag read? Anything over 3.0 ohms is a problem, and it's most likely going to be a bad clockspring.
Stock steering wheel? What's up with the communications codes? What's been removed from the car?
