Drag Racing Tech
Question about expansion tanks???
Old May 23, 2011 | 12:48 AM
BlackWS666's Avatar
Default Question about expansion tanks???
My radiator is mounted lower than i was wanting to, and know ive been told i will need a expansion tank to fill it, and to release any air inside the cooling system. Im running -16 to and from my motor to my radiator. Question is how exactly do i route the lines for the expansion tank, and what tank would work exactly. Here is my build thread, it has pictures of the setup. Thanks
https://ls1tech.com/forums/forced-in...ld-thread.html
Old May 23, 2011 | 01:40 AM
Blown06's Avatar
8 Second Truck Club
Good question. I'll be anxious to see how many different answers come up.
Old May 23, 2011 | 06:12 AM
Fireball's Avatar
I built my own expansion tank. Need a setup that doesn't have a cap on the radiator (I think). I used some spare 4" aluminum tubing to build a tank. welded a -10 on the bottom of the expansion tank and on top of one of the end tanks of the radiator. I then ran a -10 from the tank to the radiator. On the vent lines coming from the crossover tubes on the heads, I ran a -4 line from those back to the side of the expansion tank.
my tank:
pic of it on the car (look at the top right of the picture)...its on the driver side
Old May 23, 2011 | 07:01 AM
JL ws-6's Avatar
Race your car!
The radiator setup I have sitting here is the same deal that Brian built. Small radiator with -an lines to and from the motor, pump is on the radiator itself. There's a -8 line that will run from the radiator to the expeansion tank, one line off that under the cap that will run to the overflow bottle, and a port on the expansion tank to let the steam lines from the engine run back to as well. Should work out good.
Old May 23, 2011 | 07:26 AM
SlickVert's Avatar
I got my expansion tank form Mezlere. It has a cap, AN 8 at the bottom that I ran to the inlet of the pump and AN 4 about 2/3 up the side that I ran to heads vent crossover line, and over fill to a overfill tank.
Works great!
Old May 23, 2011 | 09:42 AM
BlackWS666's Avatar
Awesome guys, thanks. I was having a hell of a timing searching for this ****. My radiator does have a cap on it, can i just put a cap on it, or will i need to tig the hole shut? Thanks again!
Old May 23, 2011 | 10:17 AM
Fireball's Avatar
I'd close it off and run the cap up high...thats the purpose of an expansion tank anyway
Old May 23, 2011 | 10:46 AM
BlackWS666's Avatar
How about if i tig up the radiator cap, and run the -8 to the former cap location. Would that work good? Wial im welding up ****, should i remove the overflow hose barb piece as well? Just make it have the in/out for the pump. So that way everything else in on the expansion tank.
Old May 23, 2011 | 11:25 AM
Fireball's Avatar
thats how mine is. welding the -8 at the old cap location is fine. you want it high as possible in the radiator.
Old May 23, 2011 | 02:58 PM
BlackWS666's Avatar
Right on, I appreciate the help Fireball!! I will post up some pics whenever i get it all figured out.
