help help strange brake to moser axle bearing spacers
I guess so, with shimming my rotor our .120 then form strange build the kit for. I use no shims, and the caliper fits over but it not 100% centered. And adding shims makes it worse? They said thats fine.??
I didn't have that pic I found on GMTH. I should send them that pic and try to get thous offset backing plates. I think that would solve our problems. I wouldn't have to shim my rotor, and I could use the caliper bolt shims to center to caliper over the rotor.
anyone have stranges Email? Looks like I lost were I wrote it down last week in the shop. And can't find anything on there site anywhere??
I was someone like tech1@strangeengineering.net? I can't sit on the phone tomorrow at work
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I gotta call em tomorrow about my caliper offset ...Pass side is close to centered the drivers side the caliper is nearly touching the wheel side of the rotor ...meaning i need to remove my alxe bearing and machine spacer on the axle to get the clearance ?? wanna ask them why one side works and one is off by a mile ...all new strange axles and brakes ordered for my moser 9" with factory off set ???
Do you have a Email on any paperwork?
PN is B4170B is that wheel spacer in my front kit that work on the rear to get behind the rotors to get them from hitting the caliper bracket.
Its
.120 thick.
3.250 ID
3.740 OD
5 bolt pattern is .535 and slotted (I guess for 4.5 and 4.75?). Has another .840 pattern I think it just for weight. So not gona center on 5/8studs.
Its
.120 thick.
3.250 ID
3.740 OD
