help help strange brake to moser axle bearing spacers
ok got my new strange brakes ..I have a moser 9" looks like I need the spacers that go behind the bearings ..I know SJM makes em for 50.00 bucks .
Question are these steel ? aluminum? strange told me i need a spacer thats .145 thick i can turn these on my lathe if i know the material ...any reason aluminum wouldnt work ???
thanks really want this together for friday night ...other wise i would just oder them...
My sjm ones are steel. They are nothing special, they were not even machined nicley looks like the got some tube and use an bandsaw. way over priced for what you get. I'd imagine Aluminum would work, only thing I can think of is it might be too soft... I have no idea just a guess
Race your car!
They are steel.. I would worry that alum would squish thin after a while, develop some slop so to speak...
I really hate that whole axle spacer deal... why the hell there isn't 2 backing plates so you don't have to go shimming the axles out like that is beyond me. it's not like you couldn't just make the backing plate with that .145 of thickness built into it to pull the caliper in to the right spot.
ok steel it is ...thanks ...but the backing plate is aluminum so it the spacer collaspes one would assume the backing plate would experience similar issues ...either way i can turn it from steel ...just takes a little longer ...I agree JL i almost think strange does it outta spite for not buying there housing ...
Or if you call them to check about ordering their brake kit(s) ($1,300) , for their rear end you bought assembled form them with all there parts ($2,200). Have them look it up to make sure every will work. And BOTH brake kits don't fit. Call them about it, find out there have 2 offsets on there rear end they use. But only make one offset caliper brackets, Their solution?? put a wheel spacer behind the rotors.
sweet
sweet
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
1 Post
After having a similar problem with my Moser 12 Bolt I went and ordered the spacers from SJM. After receiving these rough looking spacers I realized that the one piece of 50 dollar pipe they cut off of must make them 1000 dollars.
My strange 12 bolt had spacers between the axle bearing and stock backing plate that was made from aluminum. Once the bolts are tightened it's not gonna move so I don't see why aluminum wouldn't work. If it was in a position where it had something turning against it or banging back and forth then steel would be the better choice.
sweet![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
sweet
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
LS1Tech Premium Sponsor
The Moser f-body rearends use a specific "flush mount" housing end that is bored deeper to allow the stock 93-02 brake backing plate to become the axle retainer with no spacers or other fittment issues. The deeper bore sinks the axle bearing completely inside the housing end, therefore resulting in a "flush mounted" aplication.
Almost all the aftermarket brake kits, Strange included, have the caliper mount(backing plate) designed with a counterbore to work with standard housing ends, which stick the bearing out of the housing end about 0.140". This is a normal setup in the aftermarket rearend and brake world. This counterbore bracket mounted to a Moser end will let the axle move in and out the amount of that counterbore in the bracket because it is not contacting the bearing as is was designed.
Strange manufactures an aluminum spacer that is the exact same profile and id as their "normal" housing end, as they do not offer a "flush mount" end similar to Moser's. This spacer effectively does the same job as the Moser flush mount end(for using stock brakes), and then allows the race type brake kit to be installed after the fact with no fitment issues or goofy bearing spacers.
So... there is nothing wrong with the way that any of it is manufactured, it's more of a matter of people trying to put specific parts from different manufacturers where they were never intended to be. If I get a chance, I will post some pics of the two so more of you will understand the differences.
I have a way to make the Moser housings(ends) work with the Strange brakes without any spacers as we use the Moser ends normally on our fabricated 9" rearends. If the customer states at the time of the order that they are using race type brakes from the start, then we use the Strange ends. If anyone is interested in this then contact us and we can get you setup on a parts exchange basis.
This ^^^, I just found this out today with my Moser 9" and strange pro series 2 drag brakes. I ordered them through SJM and got the bearing spacers too. SJM was top notch on ordering and answering questions but the fu%$ing things dont fit. The solution...... washers or spacer behind the rotor. Funny Huh. Did you use a wheel spacer? I didn't figure one would fit behind without turning the diameter down. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I have a thin front spacer that came with the front brake kit. Its from strange, I can get the PN off it, but I'm sure they can look it up. It came in the 3rd gen pro2 front kit. Its kinds thin, I think it was .120 and spaces the rotor off so it doesn't bottom out against the caliper bracket. The other think I might do, is machine them for room. I'm not in front of the parts right now, but thought about this. The lip on the back of the rotor is .090 I believe, you could take it down to .040 it just holds the clip on I think it would be fine. And put a groove in the backing plate for the rotor lip to fit, I think I only had to go 40 also on that, and should have about 20 of clearance. I dont have access to a turntable on a mill to make it nice, so haven't looking into it more. But it should work.
pardon my MS paint skiils
![](http://i2.photobucket.com/albums/y11/studderin/cut.jpg)
[IMG]
![](http://i2.photobucket.com/albums/y11/studderin/Picture016.jpg)
GMHT mag. did a S60 on some car there building a few months ago. "Chevrolet Camaro Drag Project - Beginner's Luck" and are putting drag brakes on it, the rear caliper brackets are offset inward. I called strange to see about getting a set, and they might clear the pro2 rotors. They didnt know what I was talking about and I have the right parts (that don't fit)
made a set today ...took a couple hours on my little Atlas lathe....cost me ooohhh right at Zero dollars ...turned them out of some 3/16 plate i had laying around ..measure 3.150 on the OD 2,75ish ID and right at .143/44 thick ...gonna grab some ZA and head back out and burn some midnight oil ...pics to follow ...
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I ran into this, but I bought everything from Midwest and was told going in about the situatuion. I have strange ends and used the spacer that Eric sent me with my stock brakes. After i swapped to the Strange brakes it just bolted right on.
spacers and brakes installed
Have a question for the experts ...with no shims installed the caliper is closer to wheel side ...is this normal ?? if it has to be centered the the caliper would have to be machined to gain the additional clearance
I guess so, with shimming my rotor our .120 then form strange build the kit for. I use no shims, and the caliper fits over but it not 100% centered. And adding shims makes it worse? They said thats fine.??
I didn't have that pic I found on GMTH. I should send them that pic and try to get thous offset backing plates. I think that would solve our problems. I wouldn't have to shim my rotor, and I could use the caliper bolt shims to center to caliper over the rotor.
