Which Tire
1) I'm aware of the Hoosier Street driving warning, I will be driving only to and from the track in dry weather.
2) Traction at the strip.
I would think the Hoosier because of the higher sidewall and softer compound.
But the Mickeys contact patch is 1.5" wider so?
Mickey Thompson ET Street Radial II
P315/35R17 on 17x11" wheel
OR
Hoosier Quick time Pro DOT
26x11.50-15LT on 15x10" wheel
Thanks for your opinions.
Ed
You are best of with a bias tire on a stick. The QTP is a good tire.
It is plain and simple. Radials are not very forgiving and the hard hit of the clutch makes it VERY difficult to make radials hook. Then if you do get them to hook and work they don't gain you much at all over a bias that you can slap on an kick *** from day one. I have seen some guys do side by side comparisons and they genearly gain 1-2 MPH and drop a tenth or two with a radial over a bias. Some have gained more but not often.
The point is that you spend all this money and time trying to get a radial to work most often and the reward is a nickel for your troubles.
As far as the Hoosiers go, Im running a MWC 9" spooled and she went thru the tires in about 5 months. Some street driving and too/from the track. Maybe4-5k miles and they were done.
My best 60' on the hoosiers was 1.61 at around 13psi front shocks set at 2 rears set at 50/50
Once those tires became bald, I went to a full slick. M/T ET Drag stiffwalls and holy hell they hook a ton better than the Hoosiers did for me.
Best 60' on the ET Drags 1.52 @ 16psi and the car felt alot more stable down the strip.
but other wise a Bias ply tire is MUCH easier to hook with a 6 speed car
