UPDATE PAGE 2...I gave in to the weight reduction itch. Weights inside
#47
that firewall mat is 11 I believe.
gasoline is about 6.07 6.1 #'s a gallon depending on type and temp.
here the seat weights
2001 Z28 cloth seats n
driver /power- 39.15
passanger /manual- 29.85
front seat belts- 6.696 with the bolts
http://i2.photobucket.com/albums/y11...n/DSC02620.jpg
speedinc carpet 12.910 out of the box, not cut to fit, with matting.
you still have have a lot of things you can remove for free if you want to spend the time. 50-80#s of the normal things
#50
Wow, chill out dude. Re-read the post before you go getting upset. I did say I thought he did a good job and your right no one needs the safety equip. Just the right way of doing things in a t-top unibody car regardless of e.t. run And I also stated earlier I was unaware the camaros were that much lighter than a firebird. Again, to the op I think that is a great weight for the mods done.
#52
Thanks studderin. Is the firewall mat the black mat under the peddles that go all the way to the passenger side? 11lbs is worth taken off but I wonder how much heat will be comming through without it?
I guess we could probably figure the car was somewhere in between 3440-3500lbs. I know I dont really need a cage untill 11.49 but what about subframe connectors when do you think I need those?
I sent a pm to MWC a few months ago. They told me the bumper supports are 6-7lbs each. Nothing like the Burkhart.
But I dont "need" anything do I? I mean, im not at 11.49 so no cage. I really dont see any use for bumper supports. Forget carpet I like it the way it is. So what about subframe connectors why would I need those?
Is that race weight?
#53
nah man you don't need the front/rear bumper supports.. I ordered mine from MWC just because I wanted to keep it a little stiffer than no supports at all.
Subframes will tighten the car up and feel more solid overall. It makes the car feel like its on rails, again not required though. If your not trying to autocross or going crazy at the track you don't need em.
I will most likely separate the carpet from the sound deadening for my car. I like the look of carpet in there and the fitment of GM's vice SpeedINC's etc. Can you easily separate yours and get me a weight of the carpet without the sound deadening? (Yes I have read the Weight Reduction Sticky for anyone thinking about telling me the weight is in the sticky lol) All cars are different though it would help to get an average.
#55
I agree with you about the bumper supports. Mine might hang just a bit lower now. I may get a support in future. Did your hang lower or start to sag?
#56
the frame connerters are a good idea, keep body from twisting on launch, if you ever see f-body's with kinks behind the rear wheel in the quarters it's from that. and if you just get moly tube bed it and weld it it'll weight like 10lbs if not less my buddy is gettin me some tubing to make mine. i took the front support off but left the plastic top bracket and the metal on under that it stays exactly where it was before.
#57
#58
i had a bracket that bolted to under the top of the plastic and went to the core support i believe it help support the plastic and allowed some adjustment with the bumper height and hood gap. it was just a 90 degree piece of metal with 2 bolts on top and 2 maybe 4 on the core support i only used 2 atleast.
#59
Na , No chassis work, or safty equip. Stock suspension/trq arm,Full wieght minus swaybar , a/c ( truck manifolds) , front bumper support ( intercooler)
But youve definatly , inspired me!!!!!!! THanks
#60
I really dont think that stuff is comming off very easy lol. As a matter of fact I think someone would have to pay me to separate it Iv seen posts that say its really not worth it to remove that padding but idk
