spacer under rotors on strange brakes, okay ?
I write checks with my mouth that my ass can't cash
long story short i was going to order billit specalties from midwest chassis and talked to Eric about the different options, basically for the non f-body specific wheels on the rear that fit the strange brakes were cheaper by enough to offset buying the brakes.
my next question was do they make a kit for my factory 10 bolt and i was told yes we can do that. so i proceeded to order the brakes and wheels to fit the strange style brakes....when i went to slide the rotor on it hit the aluminum caliper mount when i slide it on...so i called MWC and they said the solution was to run a steel spacer under the rotor to space it away from the mounting braket...just wanting to know if this is safe or what ?
