Drag Racing Tech
eaton posi and 600+ hp?
Old 02-27-2004, 08:38 PM
JRcamaroZ28's Avatar
Originally Posted by 383LQ4SS
Keep in mind...if you go to a spool. You have to buy a specific spool. Richmond uses a 30 degree spline...which is different from Mosers 45 degree spline axles. Cant use the Richmond. Moser does not make a spool that will work with the combo you bought. Something about the spline lenght. So if you bought an entire Moser rear with an Eaton posi and 33 spline axles...MOSER DOES NOT MAKE A SPOOL THAT FITS. I know...i couldnt believe it either. I called moser and they actually refered me to Strange. They make the correct spool with the correct spline angle and the correct spline engagement length. Also..your gears will not work with the spool/ That EAton posi is a 3 seiers cariier. All spools are 4 series carriers. So youll need new gears too if you go spool.
So then the spool in summit is not the proper one then? its part number MSR-5S1233. Made for 12-bolt and 33-spline. Also my Eaton was a Series 4 Carrier
JR
Old 02-27-2004, 09:13 PM
Camaroholic's Avatar
What he means is... if you got a 3-series carrier originally from Moser, then the axles you got were not compatible with the spool that Moser sells.
If you got a 4-series carrier with the Eaton posi, then the Moser spool will work fine (worked in mine). But if you got the 3-series (for example, with 3.73 gears), then you'll need to get the Strange spool.
Old 02-27-2004, 09:25 PM
383LQ4SS's Avatar
Right...thanks for the clarification. JR...your probably ok on getting the Moser spool.
Conrad...I think your 12 bolt with spool should hold up fine. Its a tough choice wether or not to sell that 12 bolt for a 9 inch. The good thing is that 12 bolt is damn near as good as cash in the F bod world. Your unlikely to lose too much money selling it.
Best thing about the 9 inch is you could have two or three setups ready to go. One for a street setup with a posi...one for the track with a spool etc.
My buddy just built his 9 inch out of junkyard parts and has bought a ton of parts for it at swap meets. Gears, housings, axles,,whatever.
Old 02-28-2004, 06:46 AM
EVIL's Avatar
Originally Posted by FastBlackTA
evil - was your 9 inch a direct bolt in? did you retain the ABS?
what is the weight difference between a nine inch and a 12 bolt???
thanks
conrad
yea, it was a direct bolt in. i have the stuff for abs and tcs, but i dont have the reluctor rings presses on my axles yet.
it weighed probably 15-20 lbs more.
Old 02-28-2004, 11:11 AM
FastBlackTA's Avatar
hmmmmm.........thinking about ditching the 12 bolt!
Old 02-28-2004, 12:37 PM
JF WS6's Avatar
How is the durability of a 12 bolt with spool comparable with a 9 inch with a locker?
Old 02-28-2004, 01:14 PM
EVIL's Avatar
i still broke a took off my ring gear on my 12 bolt, so that had nothing to do with the posi. the 9 inch gears a thicker plus the locker is very strong.
Old 02-28-2004, 01:23 PM
JF WS6's Avatar
That sucks. I wanted a 9 inch initially but I got "talked into" going with a 12 bolt instead by a speed shop.
Old 02-28-2004, 03:58 PM
EVIL's Avatar
the guy i got my moser 9 from wont sell a 12 bolt anymore, he will tell them to go somewhere else to get it.
Old 02-29-2004, 08:35 AM
Black Sunshine/ 00SS's Avatar
I'm guessing that I got 30 runs in on the posi, and about 5000 street miles. 9" would be the way to go, if you can afford it. I'd go with the lightweight one.
Old 02-29-2004, 09:33 AM
yeah, that seems to be the route Im looking at...it takes a little longer to get the lightweight, but it looks like its worth it!
Old 05-19-2004, 09:21 PM
  #32
Jimmy P's Avatar
How much would it cost to change the posi to a spool? I have a Moser 12 bolt with the 33 spline.
Old 05-20-2004, 05:12 PM
  #33
I just got my spool and 3.73 gear setup. Give Strange a call as they offer the correct spool for your application, Moser does NOT. I think the spool was around $170 or so.
Old 05-24-2004, 09:01 AM
  #34
8 second mod
Noyzee's Avatar
it wouldnt be to bad, under 200 for spool, under 200 for a master berring kit ect
plus fluid and gears.
you wont have abs anymore so getting the nice block from billingsley racing is a looks wise must.
other then that it is just labor unless you do it yourself
Old 09-10-2006, 12:31 PM
  #35
SILVERZZ28's Avatar
So who has tried a locker in a 12 bolt. Money aside wouldnt this be best for street and strip?
Old 09-11-2006, 02:43 PM
  #36
Whoa....this thread is back from the dead!
Old 09-11-2006, 04:35 PM
  #37
SILVERZZ28's Avatar
See I use the search function. ha
Old 09-12-2006, 08:24 PM
  #38
SILVERZZ28's Avatar
Anyone?
How about this one!
http://store.summitracing.com/partde...5&autoview=sku
Old 09-13-2006, 01:12 AM
  #39
TwoFast4Lv's Avatar
Originally Posted by SILVERZZ28
They tend to do strange things going down the track
Old 09-13-2006, 02:19 AM
  #40
SILVERZZ28's Avatar
Like? Really I would like to know whats best
Quick Reply: eaton posi and 600+ hp?
