Drag Racing Tech
Which Drag Shocks to Get Better 60's
Old 02-27-2004, 06:55 PM
Pro Mouse's Avatar
Question Which Drag Shocks to Get Better 60's
My Current set up is Stock with solid mount non ajustable Torque arm and mac lower control arms.No on my pump #6 3200 Vigilante converter,the be 60 footer I can muster up is 1.808?I was told I should be running in the 1.6'sSo without Breaking the Pocket book Which Drag shocks do you guys Recommend?
TIA
Old 02-27-2004, 11:03 PM
MUSTANGEATER's Avatar
Give Billingsley Racing a call and get his new drag shocks, the website and # is over there ----------------------->
Old 02-27-2004, 11:12 PM
gator's 99TA's Avatar
what tire are you on? even most guys with nittos (and your setup) can pull low low 1.7 times or better. i am on stock shocks, lowering springs, lca/relocation brakets and pull consistent low 1.5 60'
Old 02-28-2004, 12:17 PM
Pro Mouse's Avatar
John,OOPS!!I forGot to list my darn Tires?This is on M/T ET Streets 26x10.5 13 pounds pressure?I dont get it,It just wants to spin
Old 02-28-2004, 05:12 PM
WJ SOM SS's Avatar
Vig 3200, 26-8.5x15 ET Drags on 7.5" Convo-Pro's w/3.23's. 1.67 sixty ft. times. That's w/stock f&r shocks, V6 rear springs ('95 F-body), rt. side airbag, disconnected frt. swaybar. Hoping some good shocks will give me low 1.6's or even high 1.5's....WJ.
Old 02-29-2004, 09:39 AM
BigPlanTransAm's Avatar
i dont know whats wrong with my car but i have a bmr track pack(torque arm + x brace), lca's, panhard bar, subframes, bfg's, and ~3000 stall converter and the best i can pull is 1.8's.
my friends are telling me to buy lakewood 70/30 rear shocks from jegs or summit or something and their like $45 a piece. i think ill try them out and if i dont like them ill probably go with hals.
Old 02-29-2004, 11:38 AM
Pro Mouse's Avatar
I am probably going to try the Hal's as well,maybe from Billingsley Racing
Old 02-29-2004, 11:48 AM
WAHUSKER's Avatar
I have the HALs on my car & they certainly stiffen the rear during launch. But just spinning almost sounds more like your torque arm is adjusted wrong, giving you the improper pinion angle. Have you tried adjusting it nose down a little?
Old 02-29-2004, 07:26 PM
Pro Mouse's Avatar
My Torque Arm is a Non ajustable Torque arm...I may want to change to an ajustable one in the future?I dont know what to do yet
Old 02-29-2004, 08:43 PM
Dan
Dan's Avatar
Did you unbolt the Front Sway bar? That helped me get some better 60ft's this weekend..Seems like your air pressure is to low..Try 17lbs & go from there..Maybe run more gas to put weight back there..It might slow you down but it might not..On my 98 T/A I have Mac headers, Lid, Cutout, LCA's, Yank 3500, Tuning, 3.42 Gears..My best 60 ft on MT ET Streets is a 1.77.I was doing 1.80's this weekend compared to 1.84's the month before..
Old 03-01-2004, 09:30 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Hals work great for me.
Coach
Old 03-01-2004, 04:00 PM
Pro Mouse's Avatar
Dan,I havent tried the removal of the front sway bar yet,But My sixties were from 20 to 16 pounds of tire pressure were in the 2.03-1.937 range.My et,60' and mph in my sig is with a 3/4 to 7/8 of a tank of gas.
Old 03-01-2004, 07:40 PM
02SSZ7D's Avatar
my hal/qa1's made a ton of difference, along with bmr lca's & sfc's (love them 12 way adjustments!)
