View Poll Results: Hood Pins or Dzus Fasteners?
Hood pins
15
29.41%
Dzus Fasteners
36
70.59%
Voters: 51. You may not vote on this poll
Hood pins or Dzus Fasteners?
mine is a street car... and a race car haha
but i am willing to make the sacrifices and do a lift off hood. (already have a vfn lift off sunoco hood hanging in the garage just trying to figure out the best method of installing it the dzus seem so incredibly hard and such a pain in the ***. yea they look really cool but are they worth the hassle of installation?
They are actually not as bad as it may seem. We stayed away from them on the hood partly because we thought they would be a pain to install. Then when I made the font bumper removable (quickly), and used dzus fasteners I found they were not bad at all. There is no way you could get a dzus hood off anywhere near as quick as a pin on. You can pull either off very quickly, but we can get ours off in a couple of seconds. Also FWIW, we have gone 148 in the quarter with no signs of movement with the set up that is pictured.
Sean
Sean
Race your car!
The key to making the dzus easier to deal with, is making sure the bracket that the hood is getting attached by is nice ans solid.. if you try to get away with some flimsey dzus tabs, they are a pita I agree. There's a couple different styles now, I have only dealt with traditional ones. With 2 people you can have a dzus attached hood off in about a minute, and back on probably 2 to 3 even if it fights a little bit. Again.. a solid rail is key here.
Pins are always easier.. and if you have some of the modern style ones like pictured above they are pretty easy to deal with. Here's a link to some that are the same style, if not the same ones as pictured above. They apparently have ones that you can lock as well... if you're going to put a pin on hood on a street car I think this would be a very good idea:
http://www.deftracing.com/aerocatch_hood_pins/index.htm
That means your hood weighs 4#. I never weighed a pin on. just my SS hood(44#) and the carbon SS hood(23#) I saved around 30# with the hood and lightening the supporting peices.
By the way studderin, I put holes/cut on alot of those peices you took off. Not just 8 holes.
I think its 12 or 14lbs to exact, so its 30lbs lighter vs 40lbs. I went to a pin on several years ago I dont remember exactly what it weighed. I'll weigh my pin on hood this weekend when I am filling my nitrous bottles. No matter how you look at it the pin on hood is very light compared to the stock hood.
The convience is worth that to me....and I'm probally more hardcore than anyone on this site about weight removal. I like to remove parts lighten them and put them back on so the car stays complete as it is my dd. I've done lots of weight redution that I've never seen anyone else do.
Weight removeal is more than just disassembleing your car
Anyone do this?
How about figure out your own light weight clutch assembly?
There is lots of other stuff that has been lightened and some stuff I hav'nt got to yet. Am I gonna remove my sounddeadening? NO! Am I gonna remove my ac or cruise? NO! That's to easy and I'm not looking to ride just a motor around for my dd.
Did you figure out what you wanna do yet? I think the pins that broke ef posted are pretty nice. The link that JL posted I think is the same. I like them
#33
hiosilver, damn man thats cool. thx for the ideas. yea what did u use to cut through all that think metal perfectly like that? i see what u mean about not wanting to lose the luxury's of the car and ur removing weight in other places i love that idea! but i personally dont care about a lot of the luxuries so now i wanna do both! ur way too! thx man!
and im not too sure what i wanna do. money is super tight right now and im nervous about installing the dzus and screwing them up. but my heart is with the dzus. the fasteners look soooo clean and nice i love them. im just nervouse about buying the rails then frucking up the install.
#34
Thanks guys.... Yea a drill press and a holesaw kit is handy to have,lol. But there is more to it than that. Alot of the stuff I've done I have cut the extra flanging off also via bandsaw/plasma/ airsaw cut. I leave some weight on the table because I don't want any problem's with breakage or stuff flexing around on my dd. If I were goin you guys route and basically haveing a limited street type car I could see getting a f-body to 2800 pretty easy. Right now I'm @ a little less than 3100#(street on 18's) and my goal is 3000 in drag form (bogarts and front bar removed). Lay everthing out before you start drilling
#36
On thing tho is a pin on hood really looses no streetness for the actual driving the car. Its not removing something, the cars not louder, rides stiffer, handles worse, stops worse, anything like that. But it is alot lighter, I remove mine all the time alone it 14.8 pounds. I glued some foam under it so I set it on the roof, or just the windshield. If its windy, and you can't have somone hold onto it for 20secs while I change the 2step in the pits. I lay it in the grass. But thats happened 2 times in 2-3 years. And it was not like I was gona leave it like that for 3 hours working on the car in high winds outdoors.
#37
For the record the link JL posted is for the same pins we have on the TA. You can read out the install of them here.
We also added one of these in the front between the nostrils to help support it all. Because of where we positioned the front hood pins there was a lot or movement in the middle.
Sean
Sean
#38
Studderin it's not worth the incoveiniance to do a snapon hood to me. I've had cars with zeused on hoods and our RR BMW's was both ways and it's a pain in the *** for a 12#+/- savings. My hinges probally weigh the same as your zues rails...maybe less, I only use 1 prop shock, the latch and cable is very light and the peice that holds it is drilled up. Most of my extra weight is the hood @about 7-9# heavier.
#39
You have a bolt on hood, this thread is about using a pin on hood, with Dzus rails OR hood pins anyway. Your drilled stuff is cool glad you like it, but removing all of it is gona be lighter. My hood setup is 25-30 pounds lighter then what you did.
CamaroRacing12, ya it takes a few hours mounting the racecraft rails. I never did it before either, but once you have them on its good. I havnt had to mess with them at all, taken the fenders and the front end off a few times, and dpnt have to mess with the rails the way the rcacrafts bolt on.. The front rails go thu the fiberglass braket with nuts on the back, so when you pull the nose off I just leave the fiberglass part on. Just undo the 4 10mm nuts on the core support studs. The 5 top push clips do nothings anymore a
It bolts everything together better. The fender/hood/front bumper body panels are bolted together tight with the hood on with the 12-16 dzues.
Max weight pin on hood is the way to go. The weight saving for money spent in really good when getting the car light. And you get a cool looking hood too,
dont forget therse brakets you dont need with a bolt on hood anymore, and the rear hood stut ones too.
http://i2.photobucket.com/albums/y11...n/IMG_5080.jpg
