What mods are needed to reach 11 sec?
TCI 3500 torque converter with tranny cooler
ET streets (or at the very least Drag Radials)
LT headers
Cutout
underdrive pulley
Lid
ARA ram air (should work better then SS factory ram air)
Weight reduction
Excellent track conditions (cool weather, good prep and sea level elevation)
With a very good launch 11's are possible but low 12's would be more probable. Don't forget if it's a NHRA track they want you to have a roll bar installed.
Good luck and happy modding!
M6=all bolt-ons, Clutch, and a gear.
A4=all bolt-ons, big stall, and a gear. And some weight reduction on both.
Gear, what size? I want it for daily driver
btw best last season with shift points bouncing the rev limiter minimum 3 hits for every gear change was 13.06. The shift points have been corrected now so I'm assumeing (btw was on street tires when I ran that) that I probably would hit 12.8 or 12.9 on street tires. How much does the DR's drop it with decent launch?
Mods:
99 TA fully loaded.
Free mods (ram air, airbox lift, EGR, etc etc etc)
SLP Air lid with K & N
SLP 85mm MAF
Smooth Bellows
Hooker Cat-back
TCI Superstreet fighter 3500 Stall
3.73 gears
B & M Tranny Cooler
ASP Underdrive Pulley
BMR Lower control arms with relocation brackets
LS1 Edit + dyno tuned by Delk Performance
Best street tire run with screwd shift points at the time was 13.06 @ 105.39.
This year I'll be using drag radials (BFG) and shift points are fixed. I also plan to install either just a cut-out or a offroad Y with cutout.
Can't afford headers or any other big $$ mods presently
Thanks
