cutouts or u/d pulley??
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Tryn to drop a few tenths off me 1/4 et..anybody have any experience with these mods?? which is more cost effective as far as dropping my et a tenth or two??
thnx
thnx
dont waste you money on an underdrive pulley. I have one on my car and I saw 0 improvement in 1/4 mile. what other mods do you have on your car?? If you have full exhaust the cutouts not really going to give you much improvement but it will ain you more then the underdrive pulley
My car gained 10 rwhp on the dyno with the cut-out open vs. through the cat back. I have the graphs to show it. LT's, ORY, 3.5" Cutout, flowmaster muffler. LM will flow better than the quiet flowmaster though.
Plus you would need two cutouts to put in front of the cats to work properly. For two electric cutouts, thats $400. Spend half that on an off road ypipe with a resonator and have all that power all the time and a great sound 24/7. Then you still have $200 to spend on something else for the car like a rear set of DR's or suspension parts (panhard rod and rear control arms, etc). This is the route I would take.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
i picked up .15 sec and 1.5 mph with the underdrive pulley for 210$ and an hour install it's worth it. i used a kit from scoggin dickey, pulley, belts, and arp resueable bolt. it was either the slp or the powerbond, and yes it was the only change. don't know about goats but i took an easy 100lbs off my 01 camaro.
The asp pulley is smaller and lighter and will make your car's rpm's spin up faster. It also is less weight that your motor has to turn. Get the pulley then a cutout later. I feel the ASP pulley is the one to use and when i weight it next to the slp and the factory it was the lightest.
there ya go if the asp is noticably lighter it could be a full .2. definately worth it. i would get worried about the dampening effect if it was to light though, but should be good for a stock bottom end car. by the 60ft tires would be the biggest help but thats more $ then both these options together.
