extended wheel studs for moser 9''?
i have a moser 9'' and iam in need of 3'' wheel studs and lug nuts to pass tech does anyone have a part number and do they have the same knurl as stock axles? also do i needs extended studs in the front? if so i would apprciate a part number for those also thanks allot. matt
ARP # 113-100-7713 3.25" long
They don't have the same knurl... air compressor with an impact gun and a real stud install kit,
I got a used moser 9'' and I tried to put these in and they were too small. The diameter is bigger on the axle. If someone has another part number I'd like to know also.
I run spacers with my pro-stars front and rear, I've just been leaveing the spacers on the car and putting the ZR-1's back over them, gives the rear a little more clearance on a 17x11 and gives the front a little wider stance.
If you call Thunder Raceing, Jegs or Summit they'll get you the right parts.
