Fast 4150 or Accufab 4150
its made by scorpion performance. here are the specs: i have to look up my pricing it is in the low $500s i think
Fail Safe Design – Offset throttle shafts provide a fail-safe function so throttles CANNOT stick in the open position -- best part
Maximum Flow – 2000 cfm
Fits all 4150 applications, as well as standard open plenum manifolds
Standard 5” air filter flange
Only throttle body that fits between all fuel rails, overall width is 6.9”
Compact Low Profile Design – The lowest profile on the market, overall part height is 1.4”
No External Springs -- also awesome
Extra Vacuum Ports – Two 1/16” npt on front, one 1/8” npt on front, two 1/8” npt on rear
Sealed Throttle Shaft Bearings
Throttle Position Sensor – American-made!
Idle Air Control Motor – American-made!
Smooth yet Strong - Performs like a dream on the street, but like an animal on the track
Light Weight Aircraft Aluminum
Polished & Anodized – For additional protection, wear characteristics and corrosion resistance
