Et drag diameter question
Ryan
Anyways, those tires will grow at speed, and I would at least measure once air is in the tire.
I just ran a few calculations.
Assuming 7k redline...
26.5" running 118 mph will rev the motor to 6450 RPMS
25.0" running 118 mph will rev the motor to 6800 RPMS
Basically if you make any more power your going to need more RPM OR a larger diameter tire which in your case may help as a taller tire will have more give on the launch and give you a larger window.
I have not researched in a while the rpm limits of the motor, so I would say if someone wants to chime in or go into the GEN III section and double chk. IMO I think your fine since you set the parameters of no more power and no cage. You may not even be fast enough to need one. All will depend on how the car 60 foots.
What year is your car? I believe there are some differences in the bottom end depending on year. Someone correct me if I'm wrong?
I mounted the tires. They grew quite a bit from just mounting and air being in them. They are slightly bigger than 26.5" with 15# of air in them. I should be good now, even with no growth factored in.
I planned on the qtp 27" but figured these would be better at 26.5" with the stiff sidewall. I didn't want to run tubes and screw the tires to the rims. If this doesnt get it done then that will be my next option.
I actually think if I run out of gear the car will be faster than 11.50, so I will prolly just alter my launch and/or shift points to make it work well for both the et and mph. Thanks for the input
Ryan
