Drag Racing Tech
Manual rack help
Old Aug 24, 2011 | 02:04 PM
IllusionalTA's Avatar
I have the spohn unit, and it seem's to have a odd feeling to it... While turning, it is right, then loose, then tight and loose.. I think it has to do w/ the length of the shaft, but i dunno.. i'll lop it off and see how it goes...
Brian, is your shaft avail separately?
Old Sep 18, 2011 | 04:08 PM
drone's Avatar
I finally got a friend over to help me and we tightened the **** out of the bolt at the column and now its 100x better and its alot easier to turn as well. I'm going to tighten up every bolt on the linkage next.
Old Sep 19, 2011 | 08:24 AM
5.3LJimmy's Avatar
I finally got around to installing mine. There was a small amount of slack in the fit and it was allowing only a small amount of twist when shaking the wheel back and forth. There's not enough room to shim it so that is not an option. What I did was when drilling the new shaft for the bolt is intentionally drilled at a slight angle so that the bolt contacted the opposing sides on the slot in the column. This did a good job of tightening up the slack.
Old Sep 19, 2011 | 01:39 PM
studderin's Avatar
So you had to tap the bolt thu then?
think thats gona hold up for a while? is it passable to weld, not like a full bead but a few tacks on the joint to steering shaft?
Old Sep 19, 2011 | 02:06 PM
5.3LJimmy's Avatar
No tapping. The column has a slot in it and the stock shaft slides over this. The stock steering shaft is threaded on one side so removing this deletes the threads. The manual steering shaft slides inside the column and gets drilled for a bolt with a nut where it passes inside this slot.
I'm sure it could be welded but I was trying to avoid that so it wouldn't be a pain to remove in the future. Especially seeing as it would need to come off to drop the motor/kmember out I can see it needing to be removed/reinstalled a few times.
Old Sep 20, 2011 | 10:06 PM
drone's Avatar
that little bit of slack makes it much much harder to drive. After getting it tighter it almost felt like I had power steering back! lol.
