Drag Racing Tech
Manual rack help
Old Aug 12, 2011 | 08:58 PM
drone's Avatar
Default Manual rack help
It feels like I have a tiny bit of play in my steering wheel after installing my BMR manual rack. You can ever so lightly turn the steering wheel back and forth with no steering response and no resistance. It almost feels like it rocks back and forth in the middle before any engagement. This effect is amplified when it goes from zero resistance to manual resistance. And it is annoying as hell. I was hoping for a solid connected feel at the steering wheel.
Ill try to get under there sometime soon and try to retighten everything. I feel like the problem might be with the connection into the steering shaft. BMRs instructions said to use the stock bolt and the supplied nut. Well there was no supplied nut so I went and got a regular hex nut from the hardware store. Anything special I missed? I just dont feel like this is a solid connection like this. The steering shaft is so much bigger than the linkage. The bolts and nuts would be the only solid connecting point. If I can ever get anybody to come help me I could hold the steering linkage and have somebody wobble the wheel and see if the connection teeters.
Any other suggestions? You guys with bmr racks, did you connect with just a bolt and a hex nut to the steering shaft? Or did your linkage fit snuggly into the steering shaft?
Attached Thumbnails Manual rack help-img00658-20110510-2238.jpg   Manual rack help-img00661-20110511-0022.jpg
Old Aug 12, 2011 | 09:17 PM
N2RACINGLS1's's Avatar
I am watching this one. My rack has had play in it since I put it on in 2007. Hope you get some good information!
N2
Old Aug 13, 2011 | 07:55 AM
billybadd's Avatar
Mine is kinda like that too. I dont like it but I dont street drive my car and learned to live with it. I would fix it if theres a solution though.
Old Aug 13, 2011 | 08:16 AM
JL ws-6's Avatar
Race your car!
It's pretty much normal with nost of the manual racks. I haven't seen one in 10 years that didn't have a little play in it.
Old Aug 13, 2011 | 10:57 AM
drone's Avatar
I wish I would have known if this is normal. I did my homework and I never once came across this. I knew it would be harder to turn. More turns lock to lock. Hell I even knew I was gonna rub on the tie rods with 9 inch front rims at full turn. I was fine with all of that. I was seriously expecting a solid feel though. Maybe mine is worse, there has to be a way to make this better. I find myself constantly playing with the wheel when im driving down the road.
I hope its something with the linkage and not lash in the gears. The main benefit of rack n pinion is supposed to be a solid feel to the road so I dont know why this would be different with a manual rack n pinion. Maybe its there with the power rack but you just dont feel it with the power assist. Then again the stock connection to the steering shaft is much much much better.
Old Aug 13, 2011 | 02:27 PM
JL ws-6's Avatar
Race your car!
It's a combination of the steering shaft joints and the rack's "lash" for lack of a better term. There's some expensive military grade ujoints that you can get to build a steering shaft with, that will help a bunch but it's still not going to get rid of all of it. Nothing will, sorry.
Old Aug 13, 2011 | 02:40 PM
spaulding's Avatar
Mines quite tight ive got a d shaft and a flaming river u joint at the end of the factory stub shaft out of the colum then the d shaft then another flaming river end at the rack side i got it all through bmr as a package when i bought the kmember,arms,brakes and struts i also opened up the plate on the rack and packed it full of good grease
Old Aug 13, 2011 | 04:27 PM
drone's Avatar
Maybe I shouldn't have said a tiny bit of play in the first post. Its a very annoying amount of play. As long as I can get it better than it is now I can deal with it. The linkage was too long to fit when I got it so I had to adjust it. Is there a proper way to set this piece that maybe I did wrong? They had these little allen head screws with nuts over them. What is the proper way to tighten these? I can see how the angle could be changed with adjustment as well. Something has to be wrong there is no way that this is just how it is.
Old Aug 13, 2011 | 04:41 PM
drone's Avatar
I never saw or read anything about opening the rack up.
Old Aug 14, 2011 | 02:16 PM
RsSean's Avatar
I just got installing mine from paracing, where my intermediate shaft slides in the factory column there is play I am kinda up set there is no way as of right now that figure out how to loose the play. Beside weld the shaft to the column whice I would think maybe a bad idea.
I have some other issues with it but I guess that is the nature of the beast.
Old Aug 14, 2011 | 02:56 PM
drone's Avatar
Thats exactly where I think my play is. I wonder if I could cut off the stock connecting piece and get it welded to a D shaft.
Old Aug 14, 2011 | 02:59 PM
RsSean's Avatar
I seen that done on a few other shafts that I have seen for sale on here. I am sourcing one off craigslist and going that route.
Old Aug 15, 2011 | 07:00 AM
JL ws-6's Avatar
Race your car!
Fwiw I took mine, drilled a hole in the D shaft and bolted it together. I don't know why there's a sliding connection in the rack.... Once I put a bolt thru that, like the stock one has there was no more play there at all.
Old Aug 15, 2011 | 08:39 AM
studderin's Avatar
I think it slides for a BIG front end hit, you dont get stabbed
Old Aug 15, 2011 | 11:38 AM
JL ws-6's Avatar
Race your car!
5 pt harness If I hit something bad enough to have the column impale me, chances are I would be dead anyway.
The slide part, sounds like a factory safety thing. At the point that I am at it's certainly way past having anything factory safety, actually do anything.
Old Aug 15, 2011 | 03:12 PM
5.3LJimmy's Avatar
From the couple manual rack set ups that I've dealt with it looked to me that the shaft was smaller than the end of the column. This allows some up and down movement in the shaft before it starts turning. I believe the slack you are feeling is caused by this free play in the shaft engagement. It may be possible to shim the slack and fix it without cutting and welding on anything.
I have a manual rack setup that I'm planning on installing on my car this weekend. I have always disliked the free play and will do my best to find and remedy it. If I find a simple solution I will report it back here.
Old Aug 21, 2011 | 05:12 PM
drone's Avatar
Install it yet??
Can anybody point me in the right direction as to where I might find something to shim this with? I would need something that is the width of the flat part of the D shaft to jam in there nice and tight.
Old Aug 22, 2011 | 09:03 AM
5.3LJimmy's Avatar
Originally Posted by drone
Install it yet??
No man I didn't get to it. I decided to start with the minitub install instead. I will let you know if I find a fix.
Old Aug 22, 2011 | 05:27 PM
spaulding's Avatar
Just run a u joint at the end of the stock colum to the d shaft then u joint from there to the rack i have zero sloppieness that way ill try and get a pic later this week fwiw i have a tubular kmember with manual rack mounts on it but i dont think that makes a differance
Old Aug 22, 2011 | 06:26 PM
MADMAN's Avatar
LS1Tech Sponsor
If you use our rack kit with steering shaft then put a 5/16 bolt thru the slotted hole in the column and tighten it. There is no slop at the column.
__________________
www.madmanandcoracing.com
225-343-9029
