Drag Racing Tech
lightweight fan replacement ?
Old Aug 15, 2011 | 04:39 PM
00blacka4's Avatar
I write checks with my mouth that my ass can't cash
Default lightweight fan replacement ?
I was looking at replacement fans...i eventually want to go with a lightweight radiator...whats everyone using for lightweight fan setup...it feels like mines heavy as **** !!
Also what has to be changed in the tune and whatnot....PICS PLEASE
Old Aug 15, 2011 | 05:28 PM
JL ws-6's Avatar
Race your car!
There's 2 small SPAL fans you can put on that will go right on the radiator, tune you just need to turn them on at a lower temp, that's all.
I'll have to look for the part # I don't remember what it is.
Old Aug 15, 2011 | 06:46 PM
repo's Avatar
curious about this also. I have seen a single fan mounted to a flat aluminum plate. Looked like it dropped in where the dual fan goes but only one fan. I wander how it would be to make one work instead of two.
Old Aug 15, 2011 | 10:03 PM
studderin's Avatar
I dont think your gona save wight in the rad. I posted a pic of the weight of mine in my thread I belive
Lighter fans I wnat to do also.
Old Aug 15, 2011 | 10:41 PM
00blacka4's Avatar
those fans are retarted heavy...i work at autozone and the universal fan it called for, for a 93 LT1 which is just a circular fan was only 5.4lbs....even if you needed two of those it would be 10lbs rather than like 30 or whatever it weighs !....JL get that part number !
Old Aug 15, 2011 | 11:58 PM
nmass399's Avatar
My fan only weighed 11 pounds man, and the radiator is light too, i don't think your gonna really lose any weight off of that to be worth it.
Old Aug 16, 2011 | 01:22 AM
studderin's Avatar
01 Z28 drained rad. both fans, bothe hoses, (non PS cooler)
Old Aug 16, 2011 | 01:26 AM
repo's Avatar
just thinking outloud here, but is one of the fans only used for air conditioning? if so the other one could be discarded if your not using ac
Old Aug 16, 2011 | 07:51 AM
JL ws-6's Avatar
Race your car!
No both the fans are used on the car.
Look for a smallish SPAL fan, summit sells them, they attach to the radiator like a tranny cooler would with the pull thru plastic fastners, if ya use 2 of them like the stock setup is it will save a bunch of weight.. you just have to set the tune to turn them on pretty much all the time.
Problem, is without a shroud like the stock setup has you will only draw air thru that part of the radiator, and alot of street driving you may have a temp/cooling issue. If you run an electric water pump, and can leave that on with the fans running after a run at the track you won't have any issues, as the car will have plenty of time to cool off... on the street, I could see it possibly being inadequate.
Old Aug 17, 2011 | 06:42 AM
DBN's Avatar
DBN
I changed from the stock C5 radiator and dual fans to an AFCO radiator and single fan. The AFCO radiator and fan weighs 15#.
Old Aug 17, 2011 | 07:36 AM
JL ws-6's Avatar
Race your car!
The radiator I have here, with the fan, and the water pump on it is 19 lbs
Old Aug 17, 2011 | 09:07 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I know most of the 4th gens they have a dummy fan temp guage but if N/A and street driving should be fine I would think. Only when your running FI or 100+ deg temp days in stop and go traffic. Maybe have the fans run constantly to try to keep it as cool as possible, lower thermo, and water wetter.
More just a thought but it would be cool to ditch extra weight.
