A little suspension help with my launch
The only really prep the local track one time for test n tune, unless somebody breaks so I know some of it is track prep.
So for the crap track prep I run my front shocks full loose on the extension side and all the way tight on the compression side. My rear shocks are set to 50/50, as tight as they can be. My lca's are in the 3rd hole down, they have a very slight angle from the body mount downward to the rearend mount. Lastly, I usually put 11lbs in my tires before the burnout. My car has a cam, intake, nitrous(200 hit), bolt ons, a 3600 stall, and a 9" rearend. I'm guessing my tires arent getting hit hard enough but I'm not sure the best way to go about getting them to hit harder. Do I need to move the lca's down to the last hole, or loosen the rear shocks to let the car transfer weight faster, or possibly both? Sorry this is so long, I just tried to list as much as possible to help as I dont have a vid. Any help and advise is GREATLY appreciated!!!
That sounds cool, I didnt know you could do this until recently. I was told that I couldnt pull the timing and ramp it back in with the stock pcm, that I had to have a bigstuff3. I would love to get mine in the 1.3's but I really dont think I can without a bigger stall and a transbrake.
