bone stock motor, with a gear going 12.1s?
1 Post
cam put in about 2 years ago now. The passes video taped there were late 2008 and weight reduction performed this past winter. Changed trans to a TH400 just a few weeks ago, just waiting to go make a few runs (new tires in garage too
OP, I had spray and got a few 11.7 second passes on 50 & 75 shots, but the video above is pure N/A as was my 12.16. Cost me about 1500 for that evening.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ok here's the deal my buddy just picked up a 99 z28 bone stock ls1intake to pan,it has a lid,headers full exhaust, stock converter and stock auto, 12 bolt rear w/ 3.70 gear. Went 12.1@116mph 1.7 60fts at the track on a drag radial. Does this sound right seems way fast to me. Car had a ms3 cam at one point and was pulled and the tune was left in the ecm would that have anything to do with it? I witnessed it and don't have the timeslip bc its not my car but I just don't understand how it went so fast.
Sounds like he either still has a bigger cam in it, sprayed or fabricationg his numbers to you. I would be very leary about buying this car until I know the truth, the whole truth and nothing but the truth about his mods and his times.
I don't know what you could tell me that would make me believe an auto with a 12 bolt, stock internals and ls1 intake can trap 116. I know what it takes to get an auto trapping 116 and it's more then exhaust, gears and a lid ![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Unless he's got massive weight reduction the mods and times just dont add up.
#34
#35
Do stock 460le's have a place to see the converter, when the motor gets pulled I will be putting a cam in it so ill know for sure, but I don't wanna take the trans apart from the motor for no reason but I wanna know if there's a stall
#37
Race your car!
12.1 @ 116, if the motor is stock, it absolutely has a converter in it, and I am 100% that the car is 100% gutted... or there's nitrous on it.
Easiest way to find out. Next time said car is around..... get it on a scale. If you see anything over 3000 lbs... it's got nitrous on it, or a "old man" type cam in it, converter, etc.
Likely, everything done to the car is done in a pretty stealthy way.... but it's safe to say it's far from stock.
