I want to reduce weight in my 9 second Camaro
Hello, I have a 92 Camaro, backhalf 4-link car, all chrome moly, small block, AJE front end, pinto rack etc. the car runs 9.70's in the heat @ 138mph and its 2600lbs without me in it, race weight 2800.I want to keep my stock doors just beacause I like the roll up windows! I wonder what else I can do to reduce another 100-150 lbs of the car besides doing fiberglass body, any advice is appriciated, I'll post pics later
I do have the crash bars plastics on front and back. I wonder if there is too much weight to loose from those, any idea? I'd rather keep the glass on the doors and windshield, its nice to have the roll up windows especially in Florida's race tracks and also I'm keeping the car in enclosed trailer so I'm sure if i switch to fibirglass doors it will be pain in the rear to get in/out of the car
1 Post
I can do the plastic thing u r talking about but def. not going back to small tire, I've spend lots of $$$ to do backhalf/ 4 link suspension and it works great, the car is very consistant plus I bracket race with it.I wonder how much I will loose if i take all the plastics and supports from the front and back, might not be worth the trouble
1 Post
As far as the 4th gens go there is alot of weight to be lost off the front by just cutting off radiator support and frame rails and using chromoly(or aluminum if you can get so fancy) tubing. Running a bar from your cage through the firewall and to the frame in front of the engine allows you to cut alot of useless metal out.
Got any pics of the car? Im a big third gen fan and was going to build one before I got the deal on my car. Besides some drooling pics would help us see just what is taken out up front.
Its showing as a red X.
As for removing the crash plastic/bars you can lose about 60+ lbs. I haven't done it to my 00' because its my street car, but I did do it to my 86'. Some companies make a lightweight crash bar to replace the stocker if you want the extra support.
1 Post
I see a lot of weight loss in the front engine compartment. Depends on how far you want to go but I would run bars from your cage out to the front. After that cut all of the factory wheel wells out and cut the stock frame back a good ways and plate it off. then run moly bar to support the front end and the radiator. That should be a drastic weight drop!
