advice on new rearend gear
What factors come into play to choose the correct rearend gear? I may switch from a manual transmission to a TH400. my rearend is allready apart, I'd like to pick a gear that will work later on down the road. I dont want to tear down a rearend again in the following years to do a gear change. heres the basics of the car:
2000 camaro
race weight 3460 with driver and full bottle.
tires 28x10.50 hoosier slick
will eventually be a TH400 transmission
rearend is a moser 12 bolt
I can spin the motor to 7,200rpm.
this is a nitrous car.
car makes 600hp at the wheels on the dyno. may up the jets and make 700 eventually.
I found this richmond gears calculator on theyre webpage.
http://richmondgear.com/112901.html
It seems the 4:10 I have will still work. but I was told these calculators are not totally accurate in the real world. things like converter slippage come into play i have heard. I dont fully understand how the converter slippage works if somone can explain all this to me.
2000 camaro
4.10's should work with 28" tall tires unless you have 20% slip
