Please help setup pinion angle on T/A!!!
I run -4, as do quite a few others here. You might want to start at -2 & work your way there. Make sure car is on all 4's. I did mine on an alignment rack, but I have done it also by putting the car on bricks under each wheel. Whatever works for you.
+3 - (-7) = +10 ?
or
-7 - (+3) = -10 ?
Was that just a bad use of an example?
I'm gunna measure my angles tonite, I installed my TA and set the angle eye. I'd be curious to see what my pinion angle really is.
Thx,
Lee
with positive angle they should measure more than 180* between them
to have -3* you would want 3 degrees less than perfectly flat(180) which is 177.
One ? though. I set the pinion angle to -2.5 at first and there was a ton of vibration and noise from the tires, so I backed it off to -2, and it got better but was still a lot (sounded like the damn u-joint was just gonna snap), so I then backed it off to -1.5 and it's perfect, no vibration or noise from the tires. Well, my ? is, should I start going back more aggressive a couple turns at a time till the vibration and noise comes back and then back it off one turn so I get the most aggressive angle I can get w/o ruining the u-joint? Also, if it's vibrating and making noise like that and all, is it hurting traction b/c it's set over aggressive, or is it just not good to run it like that on the street, like should I put it back up to -2 or -2.5 when i'm at the track? Let me know what you guys think, thanks!!!
Bruce
Just what I was told.
+3 - (-7) = +10 ?
or
-7 - (+3) = -10 ?
Thx,
Lee
Like I said, I may be totally wrong. That is just my rambling geometric rationalization. I have the BMR T/A on my car as well and I still am not sure what it's set at because the example in the instructions didn't make any sense.
autos are set at -2 to -4 i believe.
