Need suspension advice
D.J.
personally i wouldnt mess with the rear suspension maybe put it on an alignment rack make sure your adjustable suspension is adjusted properly. line lock may help you get off the line too, i sure enjoy mine if nothing else makes for some bad *** burnouts
So I'd think the main things you need to address are checking out your rear Qa1s, figure out which setting they're on currently. Check your pinion angle, ensure that your lcas are at least flat as the car sits or maybe even angled downward going towards the rear of the vehicle. Make sure that the lcas are also evenly set on both passenger and driver side. And a good set of shocks up front would be a good start.
Which rpm range are you leaving in? Do you have a 2 -step? This may be a dumb one, but what clutch are you using, and how is it performing.
D.J.
The M6 trans will need some driving finesse, and if you don't have a two-step rev limiter that will also be a good investment. a M6 car has to spin a bit out of the hole to accelerate without bog, but just a bit too much and it's up in smoke also.
A few years ago, Eric helped me out with these very issues. I asked his advice, and he provided it to me, along with my MWC 9" and suspension parts.
He set me up with a good deal on the Strange single 8-way adjustable front racing shocks, and some spc 315s. I put it on the second to lowest setting and working my way up.
If you wanted to be a straight baller... Call MADAM down south and ask him about his infamous Afco's with the mysterious "valve job". He hooked me up with a set in 2009, and a friend of mine in 2008, may god what a difference. He, like Eric always offers expert advice with every phone call. Either way, good luck with the car man!
