MSD 2 Step & 2001 TA 2-wire clutch switch
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Could not find which tire was 12V. Read on here that the dark green was the one I needed to tap into. 2 step not turning on with clutch depressed.
I had to use a relay with the LPE LNC2 that I had, is the MSD box the same story?
Thanks!
Thanks!
CARTEK Racing
its a 2-wire connector and it has a green and a purple with something wire. i think i found a wiring diagram, but it needs a 87a relay. which i have, so i'll wire it in. it worked with the LPE one. i don't think the switch runs on 12v so there is no way it can give a 12v output to the 2step.
I wired mine right off the pcm, didn't have to go through the firewall. Blue PCM # 32 Grey wire Clutch Pedal Position Switch Signal. Everything functions as normal and the 2 step is only active when the pedal is to the floor.
http://www.ls2.com/boggs/torques/00pinpcm.htm
what wire did you use... the solid blue or blue/white strip?
thanks!
