Drag Racing Tech
Best Race Header??
Old Dec 13, 2011 | 12:38 PM
  #41
Firehawk441's Avatar
The last muffler used was a Dynatek split flow. We've used them alot on various applications up until QTP came out with his race muffler. His muffler is sweet.
Old Dec 13, 2011 | 12:43 PM
  #42
camscam02's Avatar
Originally Posted by SSPerformance
Don't you have a nitrous list to update
Actually maybe a couple, I'm not that far behind right now.
Originally Posted by Firehawk441
I give him credit for taking the time to find public information on his own.
I know exactly where he found it.
Where's your Christmas spirit? LOL.
Right?!? No Merry Christmas or anything. I can add to this a little bit, we found 2inch primaries to vibrant mufflers off each collector was a big gain on a stock ci nitrous car
Old Dec 13, 2011 | 01:41 PM
  #43
SSPerformance's Avatar
Can't compare a nitrous car and na
Old Dec 13, 2011 | 02:43 PM
  #44
Thanks, but we're discussing N/A Cam Only applications.
Power adders are a whole different game.
Merry Christmas.
Old Dec 13, 2011 | 03:54 PM
  #45
camscam02's Avatar
Merry Christmas.
And hence the point I put nitrous in my sentence.... Just incase anybody decides to change their setup in the future etc.
Old Dec 13, 2011 | 05:26 PM
  #46
TA1364's Avatar
I think having some sort of extension off the collector is the way to go. I'm going to test in out this spring na and nitrous.
Old Dec 13, 2011 | 05:43 PM
  #47
JL ws-6's Avatar
Race your car!
Nitrous it didn't help or hurt, a 12 inch extension off the collectors with my 402 ended up working out best for me (highest mph) although none of them made a huge difference in the ET.
I do know, that once I dropped the Y and LM1 off the car and went to strait extensions, or nothing at all the car picked up about .2 and almost 2 mph.
If I had a 4 inch muffler and a turndown off the bottom of the car, I'm sure it would have been better then the LM1 was but at that point I knew it was being choked, so I took the eliminate all of it approach. It worked for me.
Old Dec 13, 2011 | 06:01 PM
  #48
1nastyss's Avatar
Im gonna be running about a foot of 3.5 inch pipe off each collector with bullets dumped for my new motor, its an na setup, we'll see how it does, i may try a few different mufflers
Old Dec 13, 2011 | 06:02 PM
  #49
1nastyss's Avatar
Oh yeah, btw, im gonna be runnin kooks 1 7/8 stepped to 2 with the 3.5 inch collectors
Old Dec 13, 2011 | 06:42 PM
  #50
JL ws-6's Avatar
Race your car!
That is essentially what I had on my 402 when I took it apart. I was spraying it too... I had about 12 inches of pipe, a super 44 muffler on both sides and about 12 more inches after that.
I built it to be quiet, and it was quiet enough to drive around like that. On track performance, the car would run 9.5x with it, and without it... but mph about 1 mph more without it... that could have just been the weight of the system doing that though.
In the end 1/2 this stuff.. does it translate to track performance? Maybe. Maybe not... only way to find out is to try.
Old Dec 13, 2011 | 06:55 PM
  #51
I'm glad you posted this as it can be very useful to this thread on header design with almost a perfect comparison on a N/A application
You ran a production 1 3/4" header on that engine.
When I ran the same CID. as you, my 1 3/4" headers were custom built and my results were the complete opposite of yours. I ran quicker N/A WITH a y-pipe and muffler then open.
ALL headers are NOT created equal. Cool **** isn't it?
BTW. I made 3 peak RWHP open then WITH the exhaust on the dyno.
Old Dec 13, 2011 | 07:13 PM
  #52
JL ws-6's Avatar
Race your car!
That's exactly what I was trying to get at... in the end, my production headers, with an extension, ran pretty similar to what you did with a custom header and a custom Y.
So.. which setup overall was better? Who's to say. Too may other variables that play into it in the end really... but there's certainly always more then one way to get to the same end result.
I did run a 1 3/4 header on the car when I was running it n/a, when I started spraying it, the 1 7/8 stepped to 2 inch, with the 3.5 collector, and the dual 3.5 inch setup went on the car... which ended up running pretty much the same (sans the weight change) with and without the exhaust on the car... which just told me if you go big enough on the piping so the restriction is low enough it will run pretty much like there's nothing there at all. Which, was that optimal? I don't have a clue. I do know that the car picked up .2 and 3 mph with the bigger headers then what it ran with the smaller ones.... for what that's worth.
I can say that the exhaust made it pretty quiet with the pipes on vs having them off. At least from inside the car
Old Dec 13, 2011 | 07:48 PM
  #53
N/A I assume?
Old Dec 13, 2011 | 08:18 PM
  #54
TA1364's Avatar
Think there is a difference in exhaust for built race motors and stock compression motors?...
Old Dec 13, 2011 | 08:43 PM
  #55
JL ws-6's Avatar
Race your car!
Fastest it went with the small headers, was at the nov 2007 rental I went to @ atco, and it went 9.69 @ 137 there. That was the fastest I ever got the car with the small headers.
After that, I made several changes to the car that actually added about 175 lbs to it. The front 1/2 of the cage was done, exhaust was added, full size battery was added, nose support was put in so it would stop sagging/flexing as well. Car MPH wise, the car was in the 140.5 to 141 range after the bigger headers went on it.. then a little playing with the fuel jet netted the 142.5 to 143.
I would have liked to make one more atco trip in november of 08, to really see what the changes did to the car just so I could have had similar track prep and air to when it ran the best with the smaller headers. I think that would have told more of the story. Last time I ran the car the way it was, you were in the other lane. The track that day, was an unprepped surfece for lack of a better term, I was off almost a full tenth with the 60 foot' s from what the car ran a 2 weeks earlier @ lvd.
I know the MPH improvements were 100% on, ET wise it saw a solid .18, close enough to .2 for this conversation.
Atco's prep, and air would have been nice to have one more time just to see what it would have done.
  #56
JL ws-6's Avatar
Race your car!
absolutely.
Old Dec 13, 2011 | 08:50 PM
  #57
JL ws-6's Avatar
Race your car!
I will correct my last post firehwak found a video that showed the car going 9.61 on the initial runs.. I have to look at the time slip book again apparently I read it wrong the last time I was looking at it.
Old Dec 13, 2011 | 09:19 PM
  #58
Not exactly. Our N/A times were not similar.
Old Dec 13, 2011 | 09:36 PM
  #59
JL ws-6's Avatar
Race your car!
How fast did you get the car to go n/a? Just for a referance, what was the weight on it? I know my car was always a bunch heavier then yours was.
Old Dec 13, 2011 | 10:14 PM
  #60
cody161's Avatar
Firehawk441 I got on QTP's website to look at his muffler and I didn't see it on there. Tell me if I'm just plain dumb and missing it or if it isn't on there.
