Drag Racing Tech
what to do for coolant over flow tank...
Old Jan 17, 2014 | 05:30 PM
Outlaw666's Avatar
I have an ebay one that will be relocated to the rear over the winter...It's worth the extra 1lb or two of hose for peace of mind imo.
Old Jan 18, 2014 | 09:21 AM
mrstepheneades's Avatar
Left the stock aluminum tube on the end of the stock hose and took a piece of 3" boost piping and capped the ends off and drilled a hole for the aluminum tube to go in. Drilled a little big so not to air lock. You can see in the pic. Left hand side behind cold piping.
Old Feb 1, 2014 | 12:36 PM
StangEaterSS's Avatar
I found Jaz makes a recirculating coolant tank that Jegs has for $30. This is what I used.
http://www.jegs.com/i/JAZ-Products/5...oductId=751518
made a bracket to hang it below where the stock battery went.
ran the hose to the rear and popped it out thru the rubber grommet in the spare tire well. if the car ever lifts a head and pushes water, it will dump behind the tires. hopefully save the car from going right into the wall as it would if it dumped in the engine bay.
