Drag Racing Tech
driveshaft loop
Old Jan 13, 2012 | 06:17 PM
m1a2d3's Avatar
Default driveshaft loop
im hoping to go to the track this spring. my first time. at what 1/4 mile time do most tracks require a driveshaft loop?
Old Jan 13, 2012 | 06:37 PM
JL ws-6's Avatar
Race your car!
It's more of what tire do you have on the car. They see your car with anything other then a stock type street radial, you will probably be asked if there's one on the car.
Slicks, drag radials, they're probably going to ask.
For the cost of the loop.. don't take a chance.. I'd just put one on and be done with it.
Old Jan 14, 2012 | 08:09 AM
zracer323's Avatar
If you are running drag radials then it is not required. Slicks it would be.
Old Jan 14, 2012 | 08:45 AM
SCott5's Avatar
LIke what zracer said, but like JL said, for how much they are and how long it takes to put one on, I would just do it now. You can find them in the classifieds for around 40-50 bucks and brand new your looking at 100.
Old Jan 14, 2012 | 09:03 AM
m1a2d3's Avatar
for 100 bucks i guess thats cheap insurance. im debating about doing a little rear suspension work but im still running the stock ten bolt 323. car is an auto thanks for the imput
Old Jan 14, 2012 | 09:07 AM
mrdragster1970's Avatar
6 & 8 Second Club
A tip for everyone, especially quicker cars.
They now require dual loops for more & more class', so some of you might want to double check??
Old Jan 14, 2012 | 12:09 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
Cheap insurance is right. The driveshaft loop is there for a reason and it's not just the rules... it's your *** in that car at the end of the day.
all you need right here... best fitting, light weight, NHRA legal, affordable.
Give us a call. We have them in stock all the time.
Old Jan 14, 2012 | 05:22 PM
Doug G's Avatar
Yes... slicks they are required reguardless if it runs 20's or 9's
X 2
Old Jan 15, 2012 | 07:21 AM
JL ws-6's Avatar
Race your car!
I talked to one of the local Nhra inspectors recently, it's coming that the loop will be required with the radial tires as well fwiw
Old Jan 15, 2012 | 07:31 AM
senicalj4579's Avatar
Alot of guys talked me into running one a couple years ago. Iv had it on ever since.
I found a spohn in the fs section for 60-70 and went with that.
Old Jan 15, 2012 | 07:38 PM
JL ws-6's Avatar
Race your car!
For what they cost, I can't see why anyone wouldn't run one.
Old Jan 16, 2012 | 10:47 AM
sweetbmxrider's Avatar
I run a short torque arm so its in the way. Really don't feel like buying a new mount but I guess I should eventually.
Old Jan 16, 2012 | 11:10 AM
JL ws-6's Avatar
Race your car!
You can put the loop off the tq arm I have seen that done a couple times. Just make sure it clears the tunnel.
