Need some help...
Need some help...
I am wanting to get to the strip while the weather is good. I was wandering what class my car would be in so I know what safety equipment to install so they dont boot me at tech inspection.....I will be running it in Centerville, AR...State Capital In Baton Rouge, and Memphis....thanks guys
Without knowing what the car runs and basing it off your sig you defiantly need a Helmet, full length pants, closed toe shoes, a driveshaft loop(good idea) and a battery tie down.
[QUOTE=jsteele90;15865812]m6? street tires? most tracks just require battery tie down, neutral safety switch, snell aproved helmet, pants, covered toe shoes, and a overflow tank for your coolant. faster than 11.50 you need a cage. dont think you need to worry about that[/QUOT
neutral safety switch? what is that for?
Pretty much everything else has been covered. Helmet is a must. Pants, closed toe shoe and battery tie down is the basic stuff for what'd you'll be running. If you go a track rental (say a car club) vs a Test And Tune the track police will be a little more flexible and not tech your car for every little thing.
OK thanks man. I know my rear end is a 10 but it is lasting the little "racing" i do with the local ricers and mustang crews that have the pleasure of keeping at bay. but i know from a dig i would shatter that thing. spending 2100-3000 on a rear is just not possible right now. If there was a cheaper way to put a 12 or 9 under there i WOULD!! Thanks to all for the tech tips and the reality check on the 10 bolt and street tires!
