Drag Racing Tech
do relocation brackets really help your 60'
Old Mar 18, 2004 | 11:36 AM
smokinHawk's Avatar
Default do relocation brackets really help your 60'
if you have a stock height car, will the relocation brackets still help out any
a little, lot or none?
i havent seen tomay peolpe get them and i thought they helped out a lot.
are they worth it.
Old Mar 18, 2004 | 12:22 PM
FEAR THE LS1's Avatar
They helped my car out quite a bit. I was cutting 1.46-1.48 60's on average before I added then. Never had a problem hooking but I added them for the hell of it. I keep them set at the lowest/steepest angle and have been cutting 1.40-1.42 60's average now.
I would recommend them, easy mod to do and after install you have 3 different LCA angles to play with.
Lee
Old Mar 18, 2004 | 12:30 PM
foff667's Avatar
LS1TECH Sponsor
whos did you pick up? spohn or brm or another?
Old Mar 18, 2004 | 12:34 PM
Oh yea... I've got the BMR Weld-in Relocation Brackets from ThunderRacing.com
Old Mar 18, 2004 | 12:53 PM
boomcase's Avatar
I had traction issues with my nittos, I installed relocation brackets and lower control arms and it helped out quite abit.
Old Mar 18, 2004 | 01:10 PM
Flamin Raven's Avatar
They help, good mod
Old Mar 18, 2004 | 09:01 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Well worth it no doubt. It also helps to eliminate wheel hop which can destroy a rearend in the blink of an eye. It's an easy and effective mod that I think is under rated.
Good luck to you!
James
Old Mar 18, 2004 | 09:08 PM
JaSSon's Avatar
TXCAMSS, Do you run these on your car? If so which ones and which bolt holes do you set them at?Thanks,Jason
Old Mar 18, 2004 | 09:39 PM
TXCAMSS's Avatar
Actually I do run them on my car. I just recently installed them though. I run the BMR bolt-in brackets and I tacked them in once I had them loaded and locked in. I set them at the lowest (most angle) setting. I wanted the most traction possible and they definitely provide that. It was very noticable. The first time out the wife pulled a 1.47 in full street trim on ET streets when traction on those would have been questionable. You just can't win a race if you are spinning.
I hope this helps. Good luck!
Old Mar 18, 2004 | 11:50 PM
Tom's_03SVT's Avatar
HAWK,
spohn, I have a brand new set of weld ins if you want them PM me....
Old Mar 19, 2004 | 05:56 AM
smokinHawk's Avatar
Thanks but i already got the BMR weld in.
Old Mar 19, 2004 | 03:48 PM
JaSSon's Avatar
Thanks again James!
Old Mar 19, 2004 | 03:56 PM
NJSPDER's Avatar
i strongly recomend gettign weld ins. it is a bit mroe work than the bolt ins, but the brackets are basically holding over 1000lbs of force each in a modded car that hooks good(figure a 60ft in the 1.6's)
later
tim
Old Mar 20, 2004 | 06:42 AM
NastySSoo's Avatar
Good info guys. Ive been considering them also. I have traction issues and hopefully the Strange drag shocks and BMR weld in relocators will help my cause
Old Mar 20, 2004 | 09:28 AM
2camaros6702's Avatar
I have them on a stock 02 Z28
my 60ft
before 2.0
after see sig
