Drag Racing Tech
Cutting Dash With For Roll Bar
Old Mar 5, 2012 | 12:50 PM
Zero4488's Avatar
Restricted User
Default Cutting Dash With For Roll Bar
Curious to see how you cut your dash to fit with the front bar. Pictures would be great...also any tips would be killer....
-Dave
Old Mar 5, 2012 | 02:11 PM
ctjohns's Avatar
I just had to notch each corner about an inch in towards the center and then about inch and a half towards the steering wheel. Will get a couple picks when at the shop next time. I was really pleased with how nice the shop I used got the bar to tuck in.
Old Mar 5, 2012 | 06:42 PM
JL ws-6's Avatar
Race your car!
If you can (if the cage isn't already done) try to get the bars routed so you don't have to cut the dash, and can just notch the upper dash piece.. this will make for alot easier/cleaner looking deal.
if you have to notch the dash out itself, it is what it is, I used a dremel with a coarse grit sanding drum and it made quick work of the task.
Old Mar 5, 2012 | 06:50 PM
Zero4488's Avatar
Restricted User
The bar isn't in yet...I will be dropping the car off next weekend. I told him to keep it close to the a-pillar and I'll mention to try to bypass the actual dash and just go where the dash pad will be...if possible could you post some pics of that area?
-Dave
Old Mar 5, 2012 | 07:05 PM
JL ws-6's Avatar
Race your car!
I don't have any here at work, might have some at home. The drivers side you will have to notch into the metal that's behind the dash to get the bar there, but it's not a big deal to do, the wiper assy shouldn't be in the way or anything else for that matter.
Passenger's side is easy, if the bar is tight to the dash metal it won't be an issue.
Old Mar 5, 2012 | 09:57 PM
94Z28rag's Avatar
Here's the best I have of mine:
Old Mar 6, 2012 | 06:54 AM
Zero4488's Avatar
Restricted User
Thanks for the pics....still interested in seeing more...
Old Mar 7, 2012 | 01:08 AM
Blown06's Avatar
8 Second Truck Club
These are pics of the cage in my truck. Madman did this and I would say is the most amazing thing about this cage. I mean, there was no room for error here and he nailed it. Fit is perfect. I have no idea how he got this part so perfect. I mean, you look at it and can tell, it was a one cut deal cause the way it all fits back together. No cutting a little and then trial fitting...
Old Mar 7, 2012 | 01:40 AM
TurboStangJON's Avatar
My front bar goes pretty far foward and all of the underdash metal was cut flush with the firewell except for around the steering column. It's well beyond the dash and hugs the edge of the dash pad so I only had to notch a hole the size of the tubing. However, the stupid dash pad was like a pretzel and snapped into a thousand pieces. I'll try to get some pics anyways.
Old Mar 7, 2012 | 10:13 AM
TAHOE5.3's Avatar
Who's doing the install for you? If you don't mind telling.
Old Mar 7, 2012 | 02:25 PM
Zero4488's Avatar
Restricted User
I have a guy local to me that does em on the side...
Old Mar 7, 2012 | 08:13 PM
ctjohns's Avatar
Few pics of my deal. I will fine tune the edges and trim them with black door edge guard.
Old Apr 14, 2012 | 01:29 AM
1BadTA13's Avatar
any other pics of this? doing this myself very soon!
