After crash rebuild by Midwest Chassis!
Thanks!
It was a 2.5qt puke tank. When the crankcase went to the same boost level as the intake. It wasn't enough...
I hope other people have seen what can happen and make changes to make there cars safer. But you just never know what can happen.
We did also add another safety measure to keep this from happening. We installed a hobbs switch on the valley cover. That is connected to ground and the ignition. So if pressure happens in the crankcase it kills the ignition.
LSmonster, Very nice setup. If you don't have a splitter in your Wilson elbow. You may want to have one added. This will help with cylinder equalization.
ATVracr, We had a bunch of correction in that cylinder and it looks like it wasn't enough. From what we can tell it got hot and a piece broke off. Then it just torched down the side of it.
Thanks. Well be back at MIR this year if all goes as planned. Keepn the sunny side up.
Quick note and a thanks to Kurt Urban. Incase anyone else tries the hobbs switch idea. You need to run a one way valve in front of the hobbs switch. So the motor can't refire once the crankcase pressure has dropped.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
7 Second Club
do you know about how many runs on those pistons before it did that?
are you staying the same exterior color?
i think i would have retired after that one,good luck with everything & the best of luck to you!
![](http://i581.photobucket.com/albums/ss259/Dragzilla/Turbo%20LS%20Coupe/Elbow3.jpg)
The car will be the same color next year. With racing starting and the little time I have to get it done. It will be flat black and ugly all this year.
If I would have listened to my checkbook I would have retired. But racing and goin fast is worse then crack.
Pro Stock John
Was it #7 or a different cylinder that had issues?
LSmonster
Yep, took care of that. Sent everything to Wilson and they hooked me up. And again, it is good to seeing you get everything going back together... I'm sure it will be better than ever.
Thanks... It's gona be ugly this year. But it's already lighter and looking to be faster. I pick the car up on Monday. So there should be some new pics added soon.
