Can I expect anything better than a 1.9 60 on street tires?
Full Exhaust, fast 92/92, z06 heads, futral f13 cam, and 4000 stall. I just bought the car last week. 315/35/17 Kumho XS street tires on the rear. First pass was horrible, I tried launching at about 2800-3000 rpm and all I did was spin. (3.2 60 ft) Dropped the pressure to about 25 and cut a 2.2. Last pass, I dropped them to 20 psi, did a good burnout, launched at 2000 rpm, and cut a 1.9. Ran a 8.0 at 92 mph. I didnt make any more passes because it was getting late and I had to be up early for work the next day.
The previous owner says that the car has run a best of 11.3 at 119 in the 1/4 on MT drag radials. I was planning on going back to the track on Sunday to see if I could cut some better 60 ft times, should I even waste my time or wait till I get some drag radials?
LS1TECH Sponsor
With the power you have, just a waste of time. Get some drag radials.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Ive been 1.7s on 245/16s summer tires. 3500-3800 (keep it under 4K) ride the clutch just right so the motor dosn't get pulled under 4K and bog. You will have a slight wheel speed, (chirping sound) thu 1st gear and 2nd if you hammer it, but not a lot spinning. Talks so seat time but can get done, Big help not racing a loud car. Don't hot lap the car, you have to let it sit 45mins 1hr. No big burnout, don't do a long burnout or of the water, that can put alot of heat in the clutch too. The track is sticky.
http://vimeo.com/1822370
LS1Tech Co-Founder
Sure you can run on street tires. You have to gradually get into the gas, quickly floor it but not stomp on it. But you'll of course run quicker on a stickier tire.
I just went 1.95 bone stock in a 5th gen, took about 7 tries.
it IS possible to run nasty times on a true radial tire. class rules state treadwear rating of 180 or more and limit tire size. interesting class for sure, but some of the guys really have it figured out...
http://www.hughesperformance.com/ind...&id=129&Itemid=
