Drag Racing Tech
Anyone using solid suspension bushings?
Old Apr 28, 2012 | 08:30 PM
CarolinaCamaro's Avatar
Question Anyone using solid suspension bushings?
Specifically solid aluminum lca bushings. Thoughts, experiences, how is the life-span of these? I will be driving this car on the street.
Old Apr 28, 2012 | 09:51 PM
JL ws-6's Avatar
Race your car!
I know a couple people that made solid delrin ones, but not alum. Delrin holds up decent, no idea how alum will do with street use
Old Apr 28, 2012 | 10:10 PM
Gary Z's Avatar
Solid bushings won't work in stock type LCAs; some give is needed to allow twisting. Rod-ends satisfy the twist requirement but are quite noisy. Poly bushings are the usual compromise.
Old Apr 29, 2012 | 07:52 AM
Question
Why is give/ twisting needed?
Old Apr 29, 2012 | 12:18 PM
Gary Z's Avatar
Mainly because of the roll motion of the axle relative to the body. There is also some side-to-side motion due to the track bar (panhard rod) arc.
Old Apr 29, 2012 | 03:18 PM
So, would not having the motion cause breakage?
Old Apr 29, 2012 | 05:35 PM
Fbodyjunkie06's Avatar
I have rod ended solid bushings, but I never notice them making noise, but that is because my car is loud.
I just feel them.
Old Apr 29, 2012 | 06:34 PM
Gary Z's Avatar
Yes, sooner or later a stock LCA with solid bushings on both ends would break; they would be forced to flex and they are designed to not flex. If you are determined to try the experiment, there is probably little danger because it is not likely they would stay on the car long enough to break. I expect you will soon hate them. BTW, 1.5x sixtys, maybe better, are possible with completely stock f-body rear suspension including stock rubber bushings.
