What should i expect 60 ft?
02 Camaro ss
Aes forged 390 9.5-1 cr
F1A pro charger 15psi should be around 800rwhp range
Jakes performance 4l80e fmvb with t brake and billet 3600 stall
Strange 3in. Chromoly drive shaft
Strange S60 with s trac 3.73 gears
Bmr adj. TA and lca
Car weighs around 3800 with driver
I'm using afco 3870r with stock spring in rear
No front sway bar
Stock springs and bilstein shocks
Bmr turbo k and lca with race star 15 drag set up using
Hoosier 17317 DR's if you need more info let me know
Just trying to see where I should be at. Thanks
Nevertheless, you should run some pretty good ET's with that power though a braked 4l80!
With all that said .... first time out .... 1.55's and working toward 1.45's.
Without seeing your dyno sheet, it still appears that a 3,600 stall is too low. I would think closer to 4,200, but the dyno sheet would help.
I don't know what you plan on leaving with on the 2 step, but the lowest I can go is 3,000 and that would be way to close to your converter stall. I don't think you could hold your car on the line.
I have 4.88 gears, weigh 3,300 with the driver, 5,600 stall, dual Mark Williams calipers on the rear, and it is like a caged tiger when I leave at 4,000 on the 2 step. I can hold it to 4,200 and that is it.
My best 60's are in the 1.29 range and I go through the lights at about 7,500. This is with a N/A stock eliminator motor that makes around 522 hp.
See what kind of times it runs and where you are having problems. I bet we can get it resolved pretty quickly.
As I and others have said, get it out there and see where it is before you go changing too much and make changes one at a time to see what works and keep track of the results. I dropped to a 1.66 60' and still spinning more than I want. Once I get my front DA's on and the front sway off, I will get serious with my E/C settings front and rear. When I am back out, I will also have fresh plugs, wires and fuel filter to be sure it is at its best.
Subscribed .... keep us informed.
