Drag Racing Tech
Solid or Poly trans mount
Old Jun 19, 2012 | 09:16 PM
Money1's Avatar
Default Solid or Poly trans mount
I have a TH350 and solid motor mounts
Which is better solid or poly for my transmisson mount
Old Jun 19, 2012 | 10:24 PM
95killerz's Avatar
A solid trans mount can break your tail housing. Poly mount should be fine
Old Jun 19, 2012 | 11:02 PM
fenton06's Avatar
Poly, for reason above.
Old Jun 20, 2012 | 12:15 AM
jthunderz28's Avatar
If you are not a hardcore track guy, i'd go with the stock GM onebrand new on Amazon for like 50 bucks.
Took away a lot of my interior vibrations.
However if your car is a strict track car, seems that most people i know have luck with poly.
Old Jun 20, 2012 | 06:54 PM
RacerXLs1's Avatar
JL couldn't of said it better,, poly!!!
Old Jun 20, 2012 | 10:38 PM
Longbob's Avatar
Poly at the very most. I have solid motor mounts and run a factory rubber transmission mount on my stocker.
Old Jun 21, 2012 | 07:19 PM
STOCK1090's Avatar
Solid engine mounts and factory trans mount.
Old Jun 22, 2012 | 03:54 PM
Firehawk441's Avatar
Originally Posted by JL ws-6
Only way a solid one is even a viable option is if the car is motor plated and mid plated... and the transmission has an aftermarket case so it's built to handle that.
Ploy will suit you fine... no need to go any further.
YES...
