Drag Racing Tech
High compression SBE experiment
Old Jun 24, 2012 | 10:43 PM
Grr's Avatar
Grr
Default High compression SBE experiment
Thought I would post up my build for some of you to check out. First off, I dont care if you think im an idiot for doing it, I dont give a **** if you think it wont work, so dont bother with the negative comments
Anyway I wanted to build a motor that I had been kickin around in my head for quite awhile, and if it didnt work I had no one to blame but myself. I did run it for a bit today and took it up to 6800 a few times and havent had any problems, but I know its ******* tight in there!
I had to pull the trans and had a light weep from the pass side headgasket, had most of the parts laying around so I went for it.
Removed the drivetrain
Pulled the heads
Then I stopped taking pics, phone went dead!
Flycut the pistons as far as I dared, about 0.130 intake and exhaust
Heads are ported 243s that have been MILLED .125 or so
224cc intake
78.5cc exhaust
46.75cc chambers
Brian Tooley platinum dual springs with Titanium retainers
Ferrea 6000 series valves
GM .051" MLS gasket
stock rockers with Comp trunion upgrade
7.300" pushrods with .042 preload
Ebay headstuds (awesome BTW)
Cam is a EPS 236/248 .615" on a 111+3 installed straight up. Piston to valve is tight as ****, I came in at about .035-.040 on the intake and .040-.050 on the exhaust.
Finished it up today and it works! compression is right about 13:1 and Im running E85 and have to use the LS1 intake till winter when it will get a vic jr and 4150 throttle body. Car also has BBK 1 3/4 headers and Borla adjustable catback. 104mm lid ported throttle body and 1-bar SD.
I just got it running and have to pull the trans again but will be putting up a vid shortly and hope to have it done again this weekend. Also will be checking cranking compression which will be pretty high my small battery has a struggle to turn it over now. Will keep this thread updated! feel free to ask questions
Gary
Old Jun 24, 2012 | 10:48 PM
saluki's Avatar
sounds great.
Most of your pics aren't working here though
Old Jun 25, 2012 | 10:35 PM
Grr's Avatar
Grr
http://youtu.be/kgPimwzuuaI
Little vid I took today if it shows up
~Gary
Old Jun 27, 2012 | 04:05 PM
Mighty Whitey's Avatar
I like your style! I'm hoping to get in to an 11.8-12:1 stock short block setup over the winter, I only wish I could get 13:1!
Old Jul 2, 2012 | 03:58 PM
chrs1313's Avatar
Let see what she ends up doing...
Have only pushed around 12.4:1 here with .120 cuts...
Made 525rwhp with my setup and 497rwhp with 12.4:1 243 headed setup...
Old Jul 2, 2012 | 06:00 PM
Grr's Avatar
Grr
thanks chris, the car runs great, drove it around all weekend in 100* high humidity with the AC blasting the whole time, Im on my 3rd tank of E85 with the new setup already. Its going to really leave alot on the table until I get the intake changed but the tq from 3500-5000 is simply crazy. I forgot to post up some vids I took in this thread, still working on getting it tuned in some but its close enough to drive around for now, gotta order a new wideband. Cant run more than 22-23* timing in this heat, IATs are 120+ most of the time
http://youtu.be/SyqyIUsYSgg
http://youtu.be/HJJ1ElkEjiE
http://youtu.be/7g94_1FIFqg
Old Jul 5, 2012 | 12:08 AM
Fbodyjunkie06's Avatar
Love it, should really run good with the Vic Jr.
Old Sep 22, 2012 | 11:00 PM
Grr's Avatar
Grr
Finally got to the track with my new tires
stock bottom end
EPS cam 238/246 .607/.609 111+3
243s ported by me, milled to 46.8cc (.135" or so)
PTC 10"LS1 1.8 STR, 3800 stall
stock trans
10-bolt with 4.10s (a little louder after 5 1.6x 60's)
all suspension is stock except for ST lowering springs and relocation brackets
Darkstars with 295/65-15 mickeys
Still running the stock LS1 intake manifold, which is KILLING it. Just dead above 5500, man I need to put a victor on it
1.62
7.28@95
11.41@120
I think with a single plane and TB, and a set of 1 7/8 headers it would trap 125-128 and go 10's pretty easy. this intake has to be hurting me 30whp at least
Old Sep 23, 2012 | 02:46 PM
studderin's Avatar
sounds like your having fun. stock sized valves? you running the heads like the pic of the stock chamber
Old Sep 23, 2012 | 02:56 PM
fergymoto's Avatar
stock bottom end
stock trans
1.62
7.28@95
11.41@120
The intake probably doesn't even fit anymore milling 1/8" off the heads. That's a freaking ton. The port alignment has to be off. If that was a SBC/BBC intake it wouldn't of come close to bolting back on without a lot of work. I'd check into the port alignment and see where it's at.
Old Sep 23, 2012 | 07:00 PM
Grr's Avatar
Grr
Stock size valves, I smoothed the chambers and blended them in after I took that pic, that pic is at 46cc
The intake fits just fine, I milled it accordingly to get it to match up
Old Sep 23, 2012 | 07:11 PM
studderin's Avatar
you should have checked the weight of those values over the stocks. you have 10 maybe 20hp in a better VJ, and blending for what you have like that. even with that valve and that ported runner
Old Sep 23, 2012 | 07:55 PM
Grr's Avatar
Grr
got the valves with the heads or I would have done LS3 valves. I would not have bought them but im not gonna throw em out
There was ALOT more work done on the heads after that pic was taken, that is just the last one I had
Old Sep 24, 2012 | 02:17 PM
IllusionalTA's Avatar
I think you'd a genius.. I have a similar setup only diff is, non ported 317's milled. .100 and I'm already running s single plane on a lQ9.. Haven't gotten to track yet but made 450rw through a 400 on pump gas and 26* I expect it to run well.. As yours will.. Think outside the box it's the way to go... Nice job!!!
Old Sep 24, 2012 | 02:56 PM
djfury05's Avatar
pretty cool.. hurry up and get the victor on there!
Old Sep 24, 2012 | 03:13 PM
Grr's Avatar
Grr
Illusional:
yeah I saw your build on the bullet (i think) and i was like "hey thats pretty similar to mine" That super and 4500 must be working to get that through a stock 317 runner
Funny last night my buddy said after I left the track everybody was
"BULLSHIT GARY'S GOT NITROUS!!"
I just had to laugh at that, we have some pretty serious LSx stuff up here lately so its getting fun, not uncommon to see 2 turbo LSx cars side by side a couple times a day it seems, hell I think thats 25% of the people at the track now
On another note, Im very torn on throwing the turbo I have on this and seeing if the heads will stay down on 10#. See how the winter goes Im done for the year gotta work the next month straight then its gonna snow!
Old Sep 24, 2012 | 03:38 PM
Yea not sure how it works , gonna change my springs , and tune it on e98 with a lil timing. And let her eat..
Old Sep 24, 2012 | 04:08 PM
98blueSScamaro's Avatar
valve job's work wonders. just did my heads cant wait to see what it gains
Old Sep 24, 2012 | 04:28 PM
Kickin around the same idea, over winter. With some lighter valves..
Old Sep 24, 2012 | 04:57 PM
Did that as well rev T.I valves holly **** i just turned 2k ETP 215 heads into 4k heads that was not smart lol. and high rpm here i come on 12.4.1 stock pistons and rod bolts.
