Drag Racing Tech
Car trailer & Winch question
Old Jul 4, 2012 | 11:49 AM
mike13's Avatar
Default Car trailer & Winch question
I bought a flat bed car trailer with dove tail, there's a provision for a winch. My question is should I spend the money to mount a winch? I know if I broke I could get help to roll it up the ramps but what about if I broke a rear or something that made the car difficult to roll?
Looking for suggestions and opinions.
Old Jul 4, 2012 | 12:49 PM
SuperSlow02's Avatar
A good winch would drag the car up in park if you wanted it too. As JL said...never a bad idea to get one
Old Jul 4, 2012 | 01:02 PM
SS MPSTR's Avatar
Originally Posted by JL ws-6
Winch is never a bad idea
This. I've been stuck w/out one with a Big Tex trailer and pushing the car up just sucks.
Old Jul 4, 2012 | 01:05 PM
Doug G's Avatar
On my want list also....just using a come-a-long pulling up my Camaro with no motor was a bitch.
this with 15' chain and a strap
Old Jul 4, 2012 | 02:28 PM
mike13's Avatar
OK thanks guys, Is a 6,000lb winch enough?
Old Jul 4, 2012 | 03:17 PM
11SECSS's Avatar
A winch is like a insurance policy its there just incase you need it.I would think a 6,000lb would be enough I have a superwinch which is rated for 4,000 and have no problems.
Old Jul 4, 2012 | 05:02 PM
I think your suppose to double the weight of what you want to pull....just incase
Old Jul 4, 2012 | 05:43 PM
Doug G's Avatar
A 6000# is more than enough IMO....if you use a block and double the line, it doubles the rating.
I was looking at a 2-3000# one down the road. The 3/4T come-a-long pulled my car right up with the only problem being it's manual
Old Jul 4, 2012 | 06:06 PM
TurboStangJON's Avatar
I use an 8000lb warn winch along with a block to make it easy on the winch. The winch doesn't have any problem pulling a car up I just throw it on. The heaviest load I have put on it was a 71 Cadillac with 4 flat tires and that wasn't bad. Other advice would be to buy a good winch because I know several people that have off brand 10,000lb winches that won't even pull an empty F-body up a trailer.
Old Jul 5, 2012 | 01:44 PM
minytrker's Avatar
I have used 3,000lb harbor freight winches in my last 4 trailers and have have one in my enclosed trailer now. They are not the best by any means but for $100 you can't beat them. I have never had one fail or not pull a car in or on a trailer.
I just checked harbor freight and it looks like they changed brands so I dont know about the current ones.
Old Jul 6, 2012 | 10:54 AM
sweetbmxrider's Avatar
If you ever broke the rear or did something to cause a wheel to not turn, you can use plastic sliders under the tire to minimize the friction. You can also throw down a line of dish soap.
Maybe if you are wheeling and bury yourself to the frame.
