Drag Racing Tech
shocks
Old Jul 24, 2012 | 12:09 PM
blown97ss's Avatar
Default shocks
Looking at getting some drag shocks. I have the funds to buy one pair right now, wich should I buy first the fronts or back. Wich would give me better results at the track for now. Also looking at either the qa1 of strange shocks, any one of those better than the other. Thanks
Old Jul 24, 2012 | 01:23 PM
Carl at CRP's Avatar
Hopefully You will decide on the Strange shocks, if so please give Me a call. I have very good pricing on them!
Thanks,
Carl
Old Jul 24, 2012 | 03:14 PM
armyboyatc's Avatar
I would buy some AFCO rear shocks from Mad Man. Knock the most expensive set out of the way first. For the front I would buy some Strange shocks. I have a set and LOVE them. S
Old Jul 24, 2012 | 04:54 PM
onfire's Avatar
Coal Mining Director
Madman AFCO's....done!
Old Jul 24, 2012 | 05:36 PM
blown97ss's Avatar
Ok so wich should I buy first the rears or fronts
Old Jul 24, 2012 | 05:43 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
Strange shocks are by far the best bang for the buck, and I can get them to you for the same or less than QA1. Afco shocks are the most tunable in this price range, and are only about 50.00 per shock more than the Strange.
Give me a call or email... I can help you decide what is right for your needs and budget, and have the best deals. Weight transfer is usually the place to aim for control first so in most cases we will go for the fronts then the rears.
Old Jul 24, 2012 | 06:00 PM
MADMAN's Avatar
LS1Tech Sponsor
I concur with Midwest. Start at the front and work back.
All the shocks we sell( Strange and AFCO) come with our tuning and support. We can spec the correct spring combo and shock package for your needs.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jul 24, 2012 | 06:19 PM
89ROC-Z's Avatar
What's the advantage of having double adjustables? I know they adjust both compression and rebound, but i have a chance to buy strange singles and was wondering if i should hold off
Old Jul 24, 2012 | 08:38 PM
+badss+'s Avatar
I went with madman afco dbl adj. for the rears and just took off front sway til i can buy the front coil overs from madman as well.
Old Jul 24, 2012 | 08:44 PM
ccd_1606's Avatar
I was in the same position as you trying to decide what to buy. I called Midwest chassis this morning and talked to them for about 30 minutes. They were very helpful and explained everything to me. I decided to order the strange coil over kit for the front. I'm glad I called and talked to them and i will def. be calling them back for more parts since they were so helpful and willing to talk to me about what I needed for my application.
Old Jul 24, 2012 | 09:35 PM
89ROC-Z's Avatar
^^ Did you get the single or double?
Old Jul 25, 2012 | 06:53 AM
ccd_1606's Avatar
single adjustable and 275 pound hypercoils since i have weight reduction off the front.
Old Jul 25, 2012 | 11:36 AM
blown97ss's Avatar
Ok so ill look into the afco fronts now how do I know what springs to get. Do I have to weigh the car and go from there or is there another way to get the right springs.
Old Jul 25, 2012 | 11:46 AM
MADMAN's Avatar
LS1Tech Sponsor
I dont need the weight of the car. I ask a bunch of questions and then I can spec the right spring.
__________________
225-343-9029
Old Jul 25, 2012 | 03:58 PM
onfire's Avatar
Go with Madman. I've use a lot of different suppliers for different parts...you can NOT beat Madman's combo of price, customer service,knowledge, etc.
Old Jul 26, 2012 | 01:34 PM
Detroitmuscle's Avatar
is it possible to install rear afcos without the madman relocation brackets? Any pics? I know grinding would be required at minimum.
Old Jul 26, 2012 | 03:19 PM
tim99ws6's Avatar
rears will serve more immediate benefit IMO
Old Jul 26, 2012 | 03:20 PM
tim99ws6's Avatar
I used Burkhart's rear shock relocation kit on mine. Mine are true coilover's as well.
Old Jul 26, 2012 | 04:00 PM
B18B1LS1's Avatar
Why? Not disagreeing, just wondering!
Old Jul 26, 2012 | 05:58 PM
I'm not opposed to buying any madman products just wondering if I can install them now or if I have more stuff to order/make first.
