Drag Racing Tech
Pinion angle help
Old Sep 16, 2012 | 10:11 PM
25thhawk's Avatar
Default Pinion angle help
Cant seem to get rid of a vibration and noise that I have at light throttle and coasting. Also does it in neutral when coasting. Car is a 1998 camaro. With the chassis at 0, the trans output is -3, the driveshaft is 0 and the rear is 0. I have also tried drivehaft at -1 and pinion down 1 and 2. All three settings made the noise. Should I go positive with the pinion or move trans up a little, maybe -1 or -2.
Thanks
Old Sep 17, 2012 | 05:34 AM
01ssreda4's Avatar
Can you shim the trans up to zero?
Old Sep 17, 2012 | 06:46 AM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
I would go +1 or 2 with the pinion for an overall effective -1 or 2 total pinion angle. Pinion angle is the relation of rearend centerline to engine/trans centerline, angle to driveshaft on either end is not pinion angle. However, for a u-joint to operate efficiently, there should be a minimum of 1 deg of angle on either end (driveshaft angle to engine or rearend). You don't want the two at the exact same angle.
Also, have you checked your trans mount? A broken one does a good job of inducing vibration.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Sep 17, 2012 | 04:45 PM
25thhawk's Avatar
I dont think I can get trans up to 0. It will prolly hit the tunnel. New trans and yoke and u joints. Driveshaft just rebalanced. Tried both a stock and poly trans mount. It sounds like the front u joint or yoke rattles around when not under load. It is not a continuous vibration. I can try going positive with the pinion, but was thinking that going less negative with the trans was a better idea. Thanks
