Drag Racing Tech
Those with 10" Welds come in
Old Apr 7, 2004 | 09:49 PM
DEEZ98Z's Avatar
Default Those with 10" Welds come in
How many of you used a spacer? Had any problems if so?
Old Apr 7, 2004 | 09:59 PM
verbs's Avatar
spacer and a hours of grinding the calipers....get bogarts if you can
Old Apr 7, 2004 | 10:34 PM
DEEZ98Z's Avatar
I will eventually... but do not have the 2k to get them right now
Old Apr 7, 2004 | 10:46 PM
SUX2BU's Avatar
i got them on my car NO SPACERS. spacers are not NHRA leagal and your wheels will fall off!
no, seriously if you use spacers with stock studs you only get about 1/2 inch of threads. and i've known of two cars where the wheels fell off while driving because of this. just grind the chit out of them they are plenty thick.
Old Apr 7, 2004 | 11:09 PM
DEEZ98Z's Avatar
HOLY CHIT!! Thanks for the warning SUX2BU!!
Old Apr 8, 2004 | 09:22 AM
SilverGhost's Avatar
Motorboater
i ground mine to the point of breaking through them and had to stop or ruin the caliper..was still hitting a bit so i use a baby spacer..lie 1/16" or something..smallest one you can get but its all I needed to get them to clear properly.
you can always run extended studs, which I will be doing when i get around to installing them.
Old Apr 8, 2004 | 09:25 AM
Big Rick's Avatar
There was a discussion about spacers and NHRA and I think that it came down to that no where could they find a rule about them not being legal.
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
With my Prostars we had to grid them and run a spacer. I still run a spacer on the rear but I have 5/8 long studs and open lug nuts. Iam NHRA legal.
Coach
Old Apr 8, 2004 | 09:29 AM
Big Rick's Avatar
Just read the 2004 NHRA rulebook, spacers are legal! Section 5.2, last paragraph in the general regulations.
Old Apr 8, 2004 | 09:39 AM
DEEZ98Z's Avatar
It is not a problem to run longer wheel studs with the Welds.. but where can I find lug nuts that would work with the longer studs for my street tires? I really dont want to run open end lugs on my street tires too.
Old Apr 8, 2004 | 11:12 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run 15x10/7.5 Welds and no spacers. I think you guys are not grinding enuff around the edge, where the pie crust would be.
Here is my car:
http://www.pbase.com/image/5269912
Old Apr 8, 2004 | 01:03 PM
DEEZ98Z's Avatar
PSJ... do you thing that you could get some pics of your calipers growned down?
Old Apr 8, 2004 | 02:56 PM
SUX2BU's Avatar
yeah i got 15x10 in back with no spacers and there is plenty of meat left in the calipers. you guys arent doing something right.
Old Apr 8, 2004 | 03:12 PM
LS1Tech Co-Founder
I can take pictures at some point but I won't be able to for 1.5 weeks.
People tend to grind the face too much. The part that is a bear is where it curves to the sides. The curved part gets the most attention.
Old Apr 8, 2004 | 05:25 PM
DEEZ98Z's Avatar
That is ok PSJ... I will be doing the grinding tmw. Wish me luck ha ha
Old Apr 8, 2004 | 06:38 PM
LS1Tech Co-Founder
Fireball use to have some good pics, where are those?
Old Apr 8, 2004 | 07:04 PM
RUQWIKR's Avatar
...but your studs still must extend properly into the hex portion of the lug the same amount as the width of the stud...no way to be technically legal with Welds and spacers.
Old Apr 8, 2004 | 07:11 PM
NRC-Motorsports's Avatar
Default legal
you have to change the stud to make them legal with welds , but most tech guys dont check esp if you have lugs with hole covered , i used to make the guy take a lug off if they where closed ends ,when i teched at track when we build most cars we use the 5/8 stud ,than you dont have to worry about spacers ,wheels whatever
Old Apr 8, 2004 | 08:30 PM
DEEZ98Z's Avatar
John B. sent me one pic of Nineballs.
So if I dont use a spacer I dont have to use the longer studs right?
Old Apr 9, 2004 | 06:46 AM
Fast SS on TNT's Avatar
No, but a set of ARP 12mm 1.5 knurls are cheap ($25 for 10) and if you can pull your own axles, they are easy to install.
To be honest, I would not run the stock studs if you run a sticky tire on a Weld 15 X 10. But I tend to be over cautious. That's why I run 1/2 studs and Bogarts now.
Oh by the way.....$2000 for Bogarts???? Not even close. They are alot less then that!
