Drag Racing Tech
Vacuum pump?
Old Sep 27, 2012 | 10:01 PM
99slobird's Avatar
Default Vacuum pump?
I have a 402 lsx nitrous car and I'm pretty sure I need a vacuum pump. I have no power brakes and currently have no pcv, I am running a Vic jr and a accufab tb and am pushing oil in different places ..... I do have one crank case breather but I'm looking at buying a 99-2007 f250 electric vacuum pump on it but I don't know how much vacuum it actually pulls. Does anyone have any ideas or know anything about those ford vacuum pumps?
Old Sep 28, 2012 | 07:37 AM
studderin's Avatar
get a good moroso or a star and get no oil leaks, and they pick up power. Dont mess around with a cheap setup that dose nothing.
Old Sep 28, 2012 | 08:28 AM
fex77k's Avatar
Star is outstanding, no need for more than a 3 vane moroso, they have an enhanced version that pulls a bit more vacuum.
Old Sep 28, 2012 | 08:41 AM
99slobird's Avatar
Can anyone of you send me a link please?
Old Sep 28, 2012 | 09:37 AM
Bout'ItZ28's Avatar
http://www.starvacuumpumps.com/
Old Sep 28, 2012 | 10:46 AM
3fingas's Avatar
I have a gz setup for f-body. PM if interested.
Old Sep 28, 2012 | 12:18 PM
HioSSilver's Avatar
I wonder how much power a vp would pick up a bolt-on ls6??
Old Sep 28, 2012 | 12:30 PM
3fingas's Avatar
I picked up 14 with my pump pulling 11 at wot. But that's not the only benefit.
Old Oct 2, 2012 | 05:34 PM
nhra686's Avatar
Most people pick up 10-20 horses on a stock application. It also keeps oil out of your combustion chambers which is a big plus.
GZ Motorsports makes the only complete kit, and also uses the tensioner pulley to drive the pump which saves a lot of headaches and makes for a easy bolt-on installation.
GZ pumps are also designed to last a lot longer on the street than the other brands. www.GZMOTORSPORTS.com
Old Oct 2, 2012 | 07:32 PM
MikeFSKSpeed's Avatar
Moroso makes fantastic kits. Pm me if interested and I'll price you out all the components
Old Oct 2, 2012 | 09:30 PM
studderin's Avatar
I've talked to 4-5 people running the GZ kit and all of them only gained about 5whp at most they could tell. 2 people that did it back to back only saw about 2-3 whp that's hard to even notice.
Old Oct 2, 2012 | 10:31 PM
i6overboard's Avatar
I doubt the Ford unit would pull much of any vacuum by the size of it, maybe run two of them and report back??... Definitely go with Moroso or Star though. If you dont wanna run a belt drive, Star does have an electric unit$$$
Old Oct 2, 2012 | 11:42 PM
minytrker's Avatar
I have that setup on several cars, very nice setup.
I never dyno'd any our race cars without the pump but have had zero issues with very large nitrous setups and the gz pump setup. You also have to adjust how much vacuum the pump pulls to get the most from it.
Old Oct 3, 2012 | 07:11 AM
HioSSilver's Avatar
I talked to a good friend yesterday about the vp's. He is a professional engine builder, he does like Grand am stuff....24hrs daytona and other notable races. He's done some back to back on his engine dyno and said about 5 if your lucky. You also will have to run special seals or it will pull dust in around the main seals.
He also has built pretty much the 1st ls dirt motor years ago which got some rules made against it.
Old Oct 3, 2012 | 07:33 AM
studderin's Avatar
Thats not what Ive seen, did a back to back this summer on the new moroso promod pump gained 55hp on a 1K+ hp NA BBC, cast intake, 1 carb. NA class motor. That was over a older moroso non enh. 3vane that was pulling about 10". That pump is not cheap, and the motor was BIG.
Most other stuff gains at least 30 on smaller 400 cube bad street motor stuff. More on stuff with poor oil pan and control, and over 8K race stuff.
BTR has a vacum pump to test the motors for leak, its 220v. You need to have it sealed The LS stuff is not that bad, the rear main is reversed, VC gasket are captured, and all others. The older stuff can be alot harder to seal.
Old Oct 3, 2012 | 04:10 PM
nhra686's Avatar
I've talked to several customers that ran their cars on the chassis dyno before and after installing a vacuum pumps. 10-15 HP increase is average.
I run 15"HG on my 555 BBC and don't seem to suck dust through the seals, although I race on pavement so I can't be sure....
Old Oct 3, 2012 | 04:21 PM
BES Stroked Nova's Avatar
I got a 3 vane moroso older style one, pulls 12" on mine with a regulator. Its hooked up with a Jones Racing drive mandrel they custom made for my weird 35% undrive ATI balancer. very nice people there and everthing they sold me to hook up my alternator and vac pump drive works awesome. It was pricey but I needed something to work with what I had and they made it on the spot same day and shipped it out to me.
Old Oct 3, 2012 | 11:08 PM
99slobird's Avatar
I got a gz vp from 3fingas, came in today looks like a very good unit My question is what's the advantages of running a 12an line. Why so big?
Old Oct 4, 2012 | 10:12 AM
nhra686's Avatar
a -12 line has more than twice the flow capacity that a -10 line has. -10 lines work fine on smaller pumps but there is no disadvantage to having plenty of flow capacity.
Old Oct 4, 2012 | 03:19 PM
ATwelveSec02Z28's Avatar
I run the Moroso enhanced 4 vane... it borders on too big.
On nitrous the vac pump will help a bit more, and if you monitor case vac, you have a very powerful tuning tool.
