Drag Racing Tech
Bolt Sizes?
Old Oct 1, 2012 | 04:19 PM
InsaneDomestics's Avatar
Question Bolt Sizes?
Should I put a flat & lock washer on these or will I be fine just using a flat washer? Will they back off over time due to vibration?
I need to know the size of the bolts for the Trans Crossmember and I also need the sizes for the Nuts & Bolts on the Shock Mounts.
Also need the length of the K-member Bolts. I ordered some from spohn but I guess they are for thier aftermarket K-members, they were way too short... Anyone?
This is on a 98 fbody. Thanks
Old Oct 1, 2012 | 04:25 PM
MM98's Avatar
Crossmember bolts= M10X1.5X35
Shock mount bolts= M10X1.5X25 & the nuts are a M10X1.5
Old Oct 1, 2012 | 05:02 PM
Ok thanks, what about the 2 bolts that go into the Tailshaft from the Trans Bushing of a th400?
Old Oct 3, 2012 | 02:35 PM
Bump,
Old Oct 10, 2012 | 02:48 PM
Bump,
Old Oct 11, 2012 | 10:28 AM
MM98's Avatar
Are you talking about the bolts that hold the tailshaft housing on the trans case? Pretty sure those are a 3/8 bolt
Old Oct 11, 2012 | 10:32 AM
No, the bolts that hold the Trans to the Trans Mount Bushing... There is 2 of them.
Old Oct 11, 2012 | 10:42 AM
MM98's Avatar
Those are 3/8x16
Old Oct 11, 2012 | 11:33 AM
Ok Thanks
